Old 07-15-2018, 04:01 AM   #1
Mr_Eyo
Drives: 2017 Toyota 86
Turn signal wiring and fusing questions
1. If wiring aftermarket sidemarkers to the headlight turn signals, would I need to increase any fuse sizes?
2. Where can I tap turn signal power when running wires from the side mirrors? Would I have to increase any fuses here too?
Thanks.
Mr_Eyo is offline   Reply With Quote
Old 07-19-2018, 10:54 AM   #2
Mazikowski
Drives: 2013 GBS BRZ Limited
Increasing the fuse would be a bad idea since it's related to the wire size. If you increase the fuse you risk pulling more current than the wire can handle and burning up the insulation.
That being said, you shouldn't need to change the fuse, especially if what you're adding is LED.
Mazikowski is offline   Reply With Quote
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! Diode Dynamics Exterior Parts - Lighting 192 10-04-2017 11:51 AM
Right Turn signal DOES NOTHING ??? JR Whiter Issues | Warranty | Recalls / TSB 5 10-29-2016 02:40 AM
Turn Signal Wiring and lights DGM-BRZ Cosmetic Modification (Interior/Exterior/Lighting) 6 07-20-2016 11:33 PM
Turn signal wiring OURO3OROS Cosmetic Modification (Interior/Exterior/Lighting) 0 04-06-2014 10:05 AM
