Drives: Scion Frs
Recommended Rear Differential Fluid for Automatic?
Hi guys so im at 60k miles now and i thought it would be a good time to change my rear differential fluids and i was just wondering what do you guys recommend for an Automatic? (IF auto even differs from the manual)
I haven't felt any issues with the rear differential so i was wondering at what intervals should it be serviced at? |
#2 | |
Drives: 2017 toyota 86
Either Motul Gear300 75w90 Synthetic Or TriboDyn 75w90 Synthetic It’s pretty quick and easy. Not sure interval but a 20minute 35$ job. Might as well do it. |
[insert cool phrase here]
Drives: BRZ Premium
I used Mobile 1 gear oil.
All depends how much money you want to spend or which fan boy brand you want to use.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Pretty much any 75w90 synthetic gear oil can work really. But I wouldn’t worry about trying to save 10$ on a cheaper product for something that you only do once every 50k+ miles. Maybe if you do hardcore tracking and swap out fluids frequently it’ll add up.
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | humfrz (07-09-2019) |
#5 | |
Drives: Scion Frs
#6 | |
).Bubba |
| The Following User Says Thank You to humfrz For This Useful Post: | Mr.ac (07-10-2019) |
#7 | |
Drives: BRZ Premium
Besides Motul sucks fat ****. Mobile 1 all the way. As for the torque spec I think it's like 30 something ft/lbs. but I would take humfrz way. That's the way I "torque" mine.
| The Following User Says Thank You to Mr.ac For This Useful Post: | humfrz (07-10-2019) |
| How To: Change your Transmission & Differential Fluid | StaggeredHorizons | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 06-01-2019 09:41 PM |
| Differential Fluid Change Drain Plug - 10k & 40k | BRZ_F | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 01-04-2018 11:25 AM |
| Changing Differential and Transmission fluid | Seabass47 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 02-20-2017 01:21 AM |
| factory differential fluid warning | hankster | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 11-28-2012 03:49 AM |
| What Differential fluid is in your BRZ/FRS? | ft86Fan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 11-12-2012 09:57 PM |
