Old 12-24-2017, 11:44 AM   #1
BRZ_F
BRZ_F's Avatar
Drives: 2013 WRB BRZ
Differential Fluid Change Drain Plug - 10k & 40k
All I did my second differential fluid change and just wanted to share pictures below of the magnetic drain plug for both. Second still had decent amount of shavings on it.
Car is strictly a daily driver.
Sent from my KIW-L24 using Tapatalk
BRZ_F is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZ_F For This Useful Post:
humfrz (12-24-2017), monkeybike (12-24-2017)
Old 12-24-2017, 04:28 PM   #2
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
CRINGE
whats your driving style like? just for comparison purposes.
nos145 is offline   Reply With Quote
Old 12-24-2017, 05:35 PM   #3
humfrz
Well, thanks for sharing.
That shows that the magnetic plug is doing its job ......
humfrz
Old 12-24-2017, 06:21 PM   #4
BRZ_F
BRZ_F's Avatar
Originally Posted by nos145 View Post
CRINGE
It's my daily. Commute to work and the occasional spirited driving. Might redline and take hard turns a handful of times a week.
No track days or donuts. Nothing really abusive.
Old 12-24-2017, 06:30 PM   #5
Teseo
Drives: frs
Fluid brand?
Old 12-24-2017, 06:36 PM   #6
BRZ_F
BRZ_F's Avatar
Originally Posted by Teseo View Post
Fluid brand?
Mobil 1 75w-90 Synthetic Gear Lube LS for the 40k change. Used Motul 300 for the 10k change but I don't track the car or give it a lot of abuse so went with the less expensive fluid this time around. Its GL-5 so I'm sure it will work fine.
Old 01-04-2018, 10:12 AM   #7
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Nothing to worry about. Both fluids are good, using M1 for years in my WRX rear diff.
Ernest72 is offline   Reply With Quote
Old 01-04-2018, 10:25 AM   #8
Tokay444
Pretty standard stuff. Nothing to worry about.
Why isn't there a 2nd drain plug on the bottom of AT oil pan? FT86.ca Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 03-04-2017 08:40 PM
Differential drain plug thread pitch jay92 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 09-26-2016 11:45 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Metallic sludge on differential drain plug roddy Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-25-2013 03:49 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
