Old 11-07-2012, 01:12 PM   #1
hankster
hankster's Avatar
Drives: 2013 FR-S Argento
factory differential fluid warning
for the past month or so I've noticed a slight catching/roughness/vibration in the rear end when turning from a stop so I decided to change out the diff fluid as a quick and easy thing to try to see if would make a difference.
When I drained the factory fluid only 1 liter came out. I believe the specs say it should have around 1.3 liters so it was definitely low. Sludge on the magnetic drain plug.
Filled it up to the fill hole until it was just barely "weeping" out with 1.25 liters of Motul 300 LS 75w90 (LS stands for LImited Slip).
The slight catching/roughness/vibration completely gone - nothing but smoothness now.
So check your factory fluid fill levels and use quality fluids. It makes a difference.
hankster is offline   Reply With Quote
Old 11-07-2012, 01:15 PM   #2
Hanakuso
I thought we were suppose to use the normal Motul 300. Not the LS?
Hanakuso is offline   Reply With Quote
Old 11-07-2012, 02:27 PM   #3
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Thats what I thought since we don't need the FM.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 11-07-2012, 02:33 PM   #4
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
You can use either regular Gear 300 or Gear 300 LS.
Our differentials do not need the LS additives, at the same time, having it will not do it any harm, just spending a bit extra for something that isn't needed.
Adam
No Limit Motorsport is offline   Reply With Quote
Old 11-26-2012, 12:29 AM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Great, mine's been doing that for awhile now.. thousands of miles.. DOH! Changing it this week if I can get some Motul in
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-27-2012, 01:13 AM   #6
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
No Limit should be able to get it to you quickly, i got mine in 2 days from NY to Arkansas. I'm hoping to change mine out this week i should have done it when i installed the cat back but i have to put the overpipe on this week too so it will be back on the lift.
JoeBoxer is offline   Reply With Quote
Old 11-27-2012, 07:14 AM   #7
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
the motul 300 feels much better than the oe fluid
Jesse is offline   Reply With Quote
Old 11-27-2012, 09:02 AM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I just grabbed some locally. Motorcycle shops carry motul products so its easy to find a lot easier than the torco mtf I ended up ordering through amazon.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-27-2012, 09:07 AM   #9
diirk
diirk's Avatar
Drives: 4Runner
I had the same issue as the OP. changed out the fluid to Lucas and the vibration/grind is gone. I didn't measure the amount of OEM fluid I drained but the drain plug definately had a lot of material on the maganet.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 11-27-2012, 03:54 PM   #10
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Figured it would have a lot of shavings.Im planning to change all fluids at 1500 miles
IG-Joey_Soul
Old 11-27-2012, 04:23 PM   #11
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
A lot of material on the magnet is pretty standard for new diffs. S2K had a ton, RX7s had a ton, etc.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-27-2012, 09:30 PM   #12
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Adam
Yuppers.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 11-28-2012, 02:49 AM   #13
goke186
Well, i guess i know what i will be doing this week lol
FIVE AXIS DESIGN http://www.fivead.net (FIVE:AD Edition Ultramarine FR-S)
VTR http://vtrweb.com/ (Reccomended Pacific NW Shop!) [CLOSED]
AVO Turbo http://www.avoturboworld.com (Great Products for a Great Price!)
goke186 is offline   Reply With Quote
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
Is the Limited slip differential identifiable? jabbajaw99 Engine, Exhaust, Transmission 10 09-14-2012 07:23 AM
Get your Cusco Differential Cover from Kronos! KronosPerformance Transmission and Driveline 5 07-04-2012 09:33 PM
Differential growl or ratcheting Roadstercycle Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 09:13 PM
Confirmed Torsen Differential Andy Engine, Exhaust, Transmission 50 12-12-2011 11:01 PM
