Socket size for OEM struct bolts
Hi all!
I am getting ready to install SPC 81305 into the front lower struct hole and move the OEM 14mm bolts to the top struct holes. It seems like the SPC bolts need 15 and 18mm sockets. What sockets do I need for the OEM bolts? I tried searching around but came up short; would be great if someone could save me the trouble of taking off the front wheel before I run off to Lowe's ![]() Thanks! |
[insert cool phrase here]
Drives: BRZ Premium
Dude, don't you have a socket set? If not
Go buy both SAS and Metric sets. The more sockets in the kit the better.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Rust bucket enthusiast
As said, get a set, you're going to need it..
| The Following User Says Thank You to DarkPira7e For This Useful Post: | wparsons (07-02-2019) |
#4 | |
Drives: 2013 BRZ Sport-Tech
Sorry I can't help OP but I haven't done the job yet. |
#5 | |
Drives: Crapcan
https://www.lowes.com/pd/Kobalt-227-...hes/1000642747 |
iirc it's like a 17 and a 19, annoying, you need at least 4-5 sizes for the job iirc, I've gotten lazy a few times and just used an adjustable wrench.
Make sure you have a deep socket for the nut on the SPC bolt, the bolt extends far past the nut so a short socket won't get it all the way on. I found this DIY that calls out all the tools for disassembly: http://www.ft86club.com/forums/showthread.php?t=10842 Harbor freight man, save yourself a few bucks, hobbyists don't need lifetime warranty tools imho. Buy the whole set that has the one piece you need, repeat until you have just about everything. Also I don't know what a struct is, but I'm assuming you mean strut. |
Oops, been programming too much C at work, said struct when i meant struc
![]() I ended up buying a nice 224 piece set from Lowe's. Splurged a little but man it's nice to have tools finally. For future reference, the OEM bolts and nuts are all 19mm. The SPC lower bolt are different for the nut vs bolt head: 15mm and 18mm. |
| The Following User Says Thank You to SmoothIsSlow For This Useful Post: | Mr.ac (07-07-2019) |
| WTB: Stud Bolts OEM Size | redtwin | Canada Classifieds | 3 | 12-22-2017 02:50 PM |
| McGard wheel lock, wrench socket size | dssence | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 02-27-2014 02:09 PM |
| Which star socket for front seat bolts? | stockysnail | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-31-2013 02:46 PM |
| 02 Sensor Socket Size? | swift996 | Engine, Exhaust, Transmission | 6 | 08-19-2013 09:30 PM |
| What socket size and what torque amount for stock alloy wheels? | Takeshi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-01-2012 10:25 PM |
