Old 11-01-2012, 09:57 PM   #1
Takeshi
Drives: Scion FR-S 6MT.
What socket size and what torque amount for stock alloy wheels?
I could not find a definite answer online or in the manual.
What torque setting in ft-lbs do I use? The manual mentions 89 ft-lb, however this is in direct reference to the spare tire (steely). Page 318. Other online references mention 80 ft-lb for scions 2004-2008.
What size socket do I need to buy for my 1/2" torque wrench? I measured the stock wrench inner diameter, and it's about 3/4". And this is a little over 19mm. Do I use 19mm?
Thanks so much.
Takeshi is offline   Reply With Quote
Old 11-01-2012, 10:04 PM   #2
VietnamPhenom
Drives: 2013 FR-S WHITEOUT
Its a 19mm socket. The torque spec is 85 ft. lbs. for alloy and steelies. Its not the wheels but its the studs themselves.
VietnamPhenom is offline   Reply With Quote
Old 11-01-2012, 10:20 PM   #3
dsgerbc
Drives: BRZ(sold), STI
89 ft-lb, off FR-S FSM.
19mm socket.
dsgerbc is offline   Reply With Quote
Old 11-01-2012, 10:25 PM   #4
Takeshi
Thanks
Thanks for the quick replies!
2-piece stock size rotors? jm1681 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 01-16-2015 10:09 AM
Wheel Directory: Rota Torque 17x9.0 +30 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 113 09-09-2013 10:19 PM
Wheel Directory: Ace V12 18.0x8.5 +38 R2RO Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-24-2013 01:23 AM
Getting a Stock HP and Torque Spreadsheet? nquillen Engine, Exhaust, Transmission 1 09-01-2012 04:00 PM
Alloy wheels (http://www.tirerack.com/wheels/) Loki556 AUSTRALIA 8 08-22-2012 10:13 PM
