Old 06-20-2019, 03:39 PM   #1
Kilfer
Drives: Whiteout 14
Edelbrock surge tank cap failure?
Hi guys,
Been running an edelbrock SC on my frs for the last few months. Recently after an oil change I saw a lot of dried coolant in my engine bay around the surge tank/radiator area and was suspecting some sort of leak. I noticed the surge tank for the SC was a little low, so I topped it off, and went on my way. I also noticed that the cap (motorad t35) was not fitting quite 'right', in that 1. it was a little crooked, and 2. It was kinda like a pill bottle; screw it past a certain tightness and it would loosen up again. I'm assuming this isn't normal and have a replacement cap ordered. Has anyone seen anything similar in their edelbrock? I'm assuming you should be able to screw on the surge tank cap tightly right?
Thanks!
Kilfer is offline   Reply With Quote
Old 06-20-2019, 03:40 PM   #2
They'll warranty it for you. Contact your vendor, and they'll facilirate it.
Old 06-20-2019, 06:01 PM   #3
Kilfer
Drives: Whiteout 14
Thanks Mike, I'll be reaching out the shop I got it installed in. How topped off should the surge tank be when the car is cold? I see a 'Max' line, but I assume it should only be that high when the engine is hot?
Thanks!
Old 06-20-2019, 10:53 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
I don't think that's a real thing.
Old 07-03-2019, 01:13 PM   #5
diluzio91
Drives: '13 with go fast bits attached
Then you're going to the wrong vendors.
diluzio91 is offline   Reply With Quote
The Following User Says Thank You to diluzio91 For This Useful Post:
CSG Mike (07-05-2019)
Old 07-03-2019, 02:38 PM   #6
Ultramaroon
not playing cards
I googled vendors who facilirate and it looks like CSG is the only one. Those guys are amazing.
CSG Mike (07-05-2019), kritch (07-03-2019), toast (07-03-2019)
Old 07-03-2019, 04:34 PM   #7
kritch
kritch's Avatar
Drives: 2017 BRZ Limited PP
I dont know, I facilirate stuff at my job all the time. I think its more common than you think.
kritch is offline   Reply With Quote
The Following User Says Thank You to kritch For This Useful Post:
Ultramaroon (07-03-2019)
Old 07-05-2019, 04:05 PM   #8
Thanks!
It should always be above the flowing portion in the bottom, to facilitate self-bleeding.
Ultramaroon (07-05-2019)
Radium surge tank GrabTheWheel Tracking / Autocross / HPDE / Drifting 30 01-17-2022 08:35 AM
JUN GT SURGE TANK FOR FT86/BRZ scubie.brz Engine, Exhaust, Transmission 60 11-23-2020 07:48 PM
Edelbrock sc oil catch tank and filter Kojiap1 Forced Induction 1 08-16-2017 04:24 AM
SARD Surge Tank Kit w/ ITB from TAS 2017 mav1178 Engine, Exhaust, Transmission 50 05-12-2017 10:50 PM
Moto East / Deatschwerks Drop-in Surge Tank - tech & discussion Xero-Limit Engine, Exhaust, Transmission 42 04-27-2017 09:16 PM
