Old 06-10-2019, 09:24 PM   #1
brzboy
Drives: 2016 brz limited
Brz rear shaking
When turning from a dead stop left for right the rear end shakes a little until i speed up or straiten it out is that normal for the rear differential ? It’s got about 26k miles on it. 2016
brzboy is offline   Reply With Quote
Old 06-10-2019, 10:28 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
possible bent wheel? do you see any scoring/curbing on the wheels at all? could also be loose lug nuts as well.
Old 06-10-2019, 10:29 PM   #3
brzboy
No the wheels are perfect and the lug nuts are tight
Old 06-10-2019, 10:32 PM   #4
brzboy
I’ve read this is normal for a Torsen diff
Old 06-10-2019, 10:35 PM   #5
soundman98
soundman98's Avatar
try rotating the wheels front to back-- if the problem follows, it would be a wheel/tire issue. last possibility could be a bent hub-- that's easiest to check the rear of the car up in the air ferris bueller style, while idling in first gear, and watching the wheels at a specific point for deviation.
Old 06-10-2019, 10:37 PM   #6
brzboy
http://www.ft86club.com/forums/showthread.php?t=45641 according to this it is normal
Old 06-10-2019, 10:38 PM   #7
brzboy
It has done it ever sense I bought it new so it must be okay right ?
Rear shaking brzboy Engine, Exhaust, Transmission 16 06-11-2019 09:56 AM
scion frs 16 shaking. help! Kana Issues | Warranty | Recalls / TSB 20 10-16-2016 03:23 PM
Rear end shaking under acceleration enjoyminutemaid Issues | Warranty | Recalls / TSB 23 06-18-2016 05:15 PM
Shifter Shaking moe_5 Issues | Warranty | Recalls / TSB 5 12-07-2013 12:46 PM
shaking of car Adam86 AFRICA 3 05-17-2013 08:42 AM
