Drives: 2014 scion FRS
Shifter Shaking
hi i own a 2014 frs and ive noticed that every time i slam gears the shifter shakes alot, is this normal?
#2 | |
![]() Well, the shifter on the MT of my 2013 doesn't shake. You say you "slam" gears .... ?? I like to think that the proper way to slot the shifter into another gear in the FR-S is sort of like opening and closing the bolt on a 30-06, kind of slow but positive. I'm sure others will be along with some more insight.... ![]() humfrz |
Drives: Sci FR-S, Fer F355, Toy Highlander
Shift like you have an egg in your hand.. Don't force it. Slip back into neutral and then back into gear if there is resistance. Your tranny will be much happier.
Willing to bet "slam gears" means gas to the floor and upshifting from one to whatever as fast as possible, and lugging the hell out of the engine causing various things to shake. Has to be Fast and Furious related, because racecar.
Wasian Ninja
Drives: 2013 Crystal Black Silica BRZ-L
I hope you aren't actually slamming the gears in if they don't go in like a knife through warm butter its probably better to rev match a little better
check out my build thread here
![]() Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold) |
Drives: 2015 Series.Blue
First FR/RWD car? As the shifter is directly mounted to the transmission, when you load the engine and transmission, the shifter is going to move. If you're breaking traction, it will shake as the tires fight for traction.
| Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? | soulstice | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 01-24-2016 08:20 PM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 01:41 AM |
| Loud rattle, lots of shaking from shifter...not the knob...its the trans linkage | continuecrushing | Issues | Warranty | Recalls / TSB | 8 | 05-18-2013 11:56 AM |
| shaking of car | Adam86 | AFRICA | 3 | 05-17-2013 08:42 AM |
| Violent shifter shaking when loss of trsction | milenko11 | Issues | Warranty | Recalls / TSB | 2 | 12-15-2012 09:06 PM |
