Old 06-10-2019, 09:24 PM   #1
brzboy
Drives: 2016 brz limited
Rear shaking
When turning from a dead stop left for right the rear end shakes a little until i speed up or straiten it out is that normal for the rear differential ? It’s got about 26k miles on it. 2016
brzboy is offline   Reply With Quote
Old 06-10-2019, 09:32 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
if your tires are properly balanced then my bet is this be just normal operation of your Torsen limited slip diff..
HKz is offline   Reply With Quote
Old 06-10-2019, 09:33 PM   #3
brzboy
Originally Posted by HKz View Post
if your tires are properly balanced then my bet is this be just normal operation assuming of your Torsen limited slip diff..
The only thing done to the rear is wheel spacers
Old 06-10-2019, 09:33 PM   #4
brzboy
I’ve read other people have experienced this just wondering if it is “normal”?
Old 06-10-2019, 09:41 PM   #5
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Yes.
Old 06-10-2019, 09:59 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yeah any difference on tires can upset the lsd.
Could be one tire could be low on air. Check both rears tire pressure.
In few cases very rare a bad wheel bearing is the culprit.
Old 06-10-2019, 10:03 PM   #7
brzboy
If they are the same would it still be normal?
Old 06-10-2019, 10:10 PM   #8
brzboy
All tires are at 34psi
Old 06-10-2019, 10:46 PM   #9
Turdinator
Señor Member
Turdinator's Avatar
How quickly are you taking off? If you are close to the grip limit but not going hard enough to spin or are on crappy tires or slippery roads it can do that.
1974 TA22 Celica
2013 86 GT
Old 06-10-2019, 10:49 PM   #10
brzboy
The tires are the stock tires they are extremely hard, very easy to slide in but not taking off fast at all
Old 06-10-2019, 10:58 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
If I'm turning tightly in either direction with just a bit of torque the diff will chatter just like my brother's 911.
It's totally cool.
Old 06-10-2019, 11:59 PM   #12
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Yes. Not a lot but noticeable.
Old 06-11-2019, 12:19 AM   #13
brzboy
It's totally cool.
What do you mean clatter ?
Old 06-11-2019, 12:27 AM   #14
Ultramaroon
not playing cards
Chatter. It's more of a clutch-type lsd thing but the diff mounts in the 86 are mushy.
Just try not to punch it unless you mean to do a donut. If you coast through the turn, even better.
Pulley? Violently Shaking? 636 Issues | Warranty | Recalls / TSB 15 05-15-2018 12:54 AM
scion frs 16 shaking. help! Kana Issues | Warranty | Recalls / TSB 20 10-16-2016 04:23 PM
Rear end shaking under acceleration enjoyminutemaid Issues | Warranty | Recalls / TSB 23 06-18-2016 06:15 PM
Shifter Shaking moe_5 Issues | Warranty | Recalls / TSB 5 12-07-2013 01:46 PM
shaking of car Adam86 AFRICA 3 05-17-2013 09:42 AM
