Old 10-19-2013, 08:36 PM   #1
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
Rear end shaking under acceleration
Hi all, I've noticed that when I start from a stop in first gear at a slow to moderate pace, sometimes the rear end will shake and sort of hop. The wheels don't hop, and I don't lose traction. It is more noticeable when I have the wheel turned, so I'm wondering if it has something to do with the differential. Anyone else notice this?
enjoyminutemaid is offline   Reply With Quote
Old 10-19-2013, 08:57 PM   #2
ThaBigUnit
Awesome Member!
ThaBigUnit's Avatar
Drives: 2013 Scion FR-S (Asphalt)
No
ThaBigUnit is offline   Reply With Quote
Old 10-19-2013, 09:03 PM   #3
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Im afraid That this does not occur for me
Young_makaveli is offline   Reply With Quote
Old 10-21-2013, 12:26 PM   #4
TurboBrett
Drives: 13 BRZ
I notice this, yes, and can sometimes hear it as well.
See if any of this sounds like your issue:
http://www.ft86club.com/forums/showthread.php?t=45641
EDIT: Only on cold start and only for a turns.
TurboBrett is offline   Reply With Quote
Old 10-22-2013, 12:28 AM   #5
Raiin
Raiin's Avatar
Also noticed this and have wondered; can't reproduce it on a consistent basis...but it is more common then I would prefer.
Raiin is offline   Reply With Quote
Old 10-22-2013, 12:54 AM   #6
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Mines never shake, but makes a loud pop/thunk when I turn the wheel all the way and start moving from idle.
LeeMaster is offline   Reply With Quote
Old 10-22-2013, 09:01 AM   #7
Suberman
Drives: Subaru BRZ Sport Tech Satin White
If a tire begins to slip at slow speeds you may get a sensation of wheel hop. That's the way Torsen diffs work. This happens more frequently in slow speed corners. The slower and tighter the corner the more you will notice this. Most of this effect occurs in first gear.
The effect can even trigger the flashing yellow light on the traction control when no traction control is required.
Suberman is offline   Reply With Quote
Old 10-22-2013, 09:41 AM   #8
Foobar
SLO NO MO
Foobar's Avatar
Try it with the nannies off? Just wondering if you're getting some wheel spin and the nannies are kicking in oddly leading to a hopping type of feel.
Old 04-12-2014, 09:51 PM   #9
enjoyminutemaid
Bringing this thread back from the dead. I still get this all of the time, but only when the wheel is turned and I'm starting out from a stop. It's fairly violent though, and it feels like the rear diff is acting in a way it shouldn't. I will try to film it and set if I can get a noise. It is NOT simply the rear tires skipping, though it may be related, and it definitely reminds me of wheel hop.
Old 04-12-2014, 10:16 PM   #10
BRZnut
Drives: BRZ DGM Limited
I get this every day in the am when leaving our street first thing in the morning, but is not "violent"
Old 04-12-2014, 10:39 PM   #11
Ozzman
Drives: old
It's your limited slip differential doing it's thing. How many miles do you have on the car?
Ozzman is offline   Reply With Quote
Old 04-13-2014, 10:46 AM   #12
enjoyminutemaid
35k miles.
Is there no way to change things so that instead of the shaking, it just spins tires (other than launching)? I wouldn't mind that...
Old 04-13-2014, 11:14 AM   #13
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Sounds like it's binding....aka my ford ranger fx4 has a LSD-clutch style though and without a friction modifier it will do the same thing you're describing, but in saying that we have a torsen(frs/brz) so it's not really related. My guess; it sounds like the fluid is too low or has gone bad! I would get them to change the diff fluid at the dealer and go from there but if it's still doing it then write down the conditions it's happening and get the tech to replicate it exactly as yor noticing it. That way you might have a better shot at getting it warranties should something be wrong mechanically. Good luck
Gords_zenith is offline   Reply With Quote
Old 04-13-2014, 03:50 PM   #14
Ozzman
Drives: old
If you havn't changed your fluid yet do so.
Pulley? Violently Shaking? 636 Issues | Warranty | Recalls / TSB 15 05-14-2018 11:54 PM
Doors shaking like a mother empower-auto Electronics | Audio | NAV | Infotainment 16 10-08-2013 11:30 AM
shaking of car Adam86 AFRICA 3 05-17-2013 08:42 AM
Severe Shaking while in Idle from 0-5 mph ScionFR-S Engine, Exhaust, Transmission 1 10-15-2012 09:42 PM
CEL Blinking/Hard Shaking. _F-R-S_ Issues | Warranty | Recalls / TSB 4 09-16-2012 07:43 PM
