CANADA Canada
Old 06-07-2019, 05:52 PM   #1
TOtS
Drives: 2018 BRZ tS
Uncatted Header - worth the trouble? what can I expect?
Thinking of buying OpenFlash Header for my BRZ
What consequences can I expect of having an uncatted header?
My car is registered in Quebec.
1. will I get in trouble with the cops?
2. do I have to revert back to stock every time I have to go for mechanical inspection?
3. anything else I should be aware of?
TOtS is offline   Reply With Quote
Old 06-07-2019, 10:29 PM   #2
StraightOuttaCanadaEh
Wes
1. Nah
2. You don’t have to go for inspections anymore
3. Nah, go have fun! Make sure you get a tune
Instagram: @gt86ws
Old 06-07-2019, 11:32 PM   #3
TOtS
Drives: 2018 BRZ tS
1. Nah
Awesome
Thanks!
Old 06-07-2019, 11:46 PM   #4
86MLR
86MLR's Avatar
Cool story bro story from 86MLR:
I have noticed no real difference between MY17 decated header and a Tomei UEL header ($800AUD), that was with a 2.5" overpipe, catless 2.5" front pipe and 2.5" cat back.
Ecutek tuning
Actually, the only real noticable difference the UEL had was the deafening noise now at cold start.
So I replaced the OEM cated front pipe and full OEM exhaust which lost a little up top but knocked cold start noise right down. Exhaust was much quiter.
From there I punched out the cat in the OEM overpipe.
Cold start is now still pretty loud (I defeat it by resting my foot on the accelerator), cold start is now 105db, once cold start is finished the exhaust idles at 63db and tops out at 83db at 7k rpm.
So, now, my car doesn't have a heat signature of a Carl Gustaf rocket laucher, but makes the same power as when it did.
I am seriously contemplating replacing the decated OEM header, the only real noticable difference the UEL header has over the OEM decat is annoyingly loud cold start and a dropped cylinder beat.
Moral of the story, don't waste your time with a UEL header, a OEM header with it's guts knocked out will flow typical at these power levels.
If you do get a aftermarket header make sure it flows better within your powerband than a decated OEM header.
Someone should send you and me a ACE A350 for "comparison testing".
Opinions may vary
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 06-08-2019, 04:10 AM   #5
TOtS
Drives: 2018 BRZ tS
Ecutek tuning
Opinions may vary
Thank you for sharing!
Do you think I would lose a noticable amount of power (compared to alternatives) with an UEL?
I picked UEL hoping to get a nice rumble, that would be complemented later on by a header/cat back exhaust system .
Old 06-08-2019, 04:53 AM   #6
86MLR
86MLR's Avatar
Lose power with a catles UEL header, no, make power compared to a punched out OEM header, no.
Any aftermarket catless header will be better than a cated one.
If you want to make more power, as stated, I haven't tried a good aftermarket 4:2:1, maybe a ACE or JDL would give me more? Maybe?
Honestly, I would decat the OEM and used the money saved for dyno time with a Ecutek tuning solution.
After you remove the restrictions from the cats, it all about a "good" tuners ability and having a play for a while.
Later if you need another 5hp or torque you can look at dropping $1-2k on it.
Have a look at fluid dynamics IRT header and exhaust design.
If you want the rumble, a UEL header will give you that, it will be louder with the 2.25" OEM front pipe punched out and stock exhaust, a 2.5" catless exhaust with a resonator and rear box will be loud to the point of being annoying.
I cannot really comment on sound as that is too subjective.
Me, I just like to have the most power, with the least noise.
OEM exhaust parts are cheap, sometimes free, so playing around costs next to nothing.
Have fun
Opinions may vary
Old 06-08-2019, 09:40 AM   #7
TOtS
Drives: 2018 BRZ tS
Have fun
Opinions may vary
I started thinking about replacing the header when I saw this deal: https://clubstore.brzworld.ca/produc...h-header-combo
$1050 CAD for OFT + OFH (approx $780 USD)
I like the OFT because I can always revert back to stock if I need to go in for warranty work.
Old 06-08-2019, 09:50 AM   #8
Lantanafrs2
Drives: 2013 frs red
Ofh has been discontinued. I would check if its actually in stock before making a decision lol
Old 06-08-2019, 10:11 AM   #9
BRZ Guy
Drives: 2018 BRZ
I believe that the price is USD not CAD, I emailed ways back.
Not 100% sure...
BRZ Guy is offline   Reply With Quote
Old 06-08-2019, 11:41 AM   #10
TOtS
Drives: 2018 BRZ tS
Not 100% sure...
Ah you're right.. it is USD.
That's strange for a .CA site
Old 06-08-2019, 07:48 PM   #11
BRZ Guy
Drives: 2018 BRZ
I agree. I got excited on the price too.
Old 06-17-2019, 10:13 PM   #12
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
There is somebody local selling a OFH V2 for $500 CAD.
I've seen used OFT's selling for 450-500 which puts it right around 1000 bucks which is a good deal.
I'm tempted but I'm going Catted UEL when the time comes.
Is over pipe worth getting after installed header? stlgrym3 Engine, Exhaust, Transmission 6 03-02-2023 01:37 PM
Uncatted header install rtalich Engine, Exhaust, Transmission 7 12-14-2017 06:38 PM
Deepest catback you've heard -- but with an uncatted uel header autograph Engine, Exhaust, Transmission 14 05-12-2015 03:40 PM
UEL uncatted Header + OP/FP + Stock CBE Thoughts and anyone else running this? Aztec Engine, Exhaust, Transmission 5 03-09-2015 01:28 PM
Best <$1k uncatted EL header??? M23 Engine, Exhaust, Transmission 30 02-19-2015 01:15 AM
