Old 12-14-2017, 12:24 PM   #1
rtalich
Drives: 2015 BRZ Series.Blue
Uncatted header install
Just checking to see if anyone else has experienced this. I recently replaced my stock header with the Gruppe-S. Immediately noticed exhaust smell which I knew would happen and am OK with... if it stays outside. But when I turn on the climate control its almost unbearable. I can't hear any leaks... but I think I must have a leak somewhere. Any ideas? Or is this normal?
Thanks!!
rtalich is offline   Reply With Quote
Old 12-14-2017, 02:39 PM   #2
dattran86
Driver
Drives: 2013 Whiteout FRS
possible that WD-40 was spray onto the nut, in order to break it loose easier?
when I was doing the header swap and spray WD40 on the nut, after i got the aftermarket one in and start up the car. it started smoking and smell really bad, turn out it was just the WD-40 burning because the engine/exhaust heat up.
it should go away after a day
Check out my website:
http://www.aim4apex.com/
IG: aimforapex
dattran86 is offline   Reply With Quote
Old 12-14-2017, 03:22 PM   #3
NRXRaptor
I forgot to take a sticker off a front pipe before I installed it. It melted and I thought I melted something important before I realized. I'd wait a week to see if it goes away
NRXRaptor is offline   Reply With Quote
Old 12-14-2017, 03:28 PM   #4
tyler_win_photo
tyler_win_photo's Avatar
Check the connection to the overpipe, that's where most leaks usually come from from header installs
tyler_win_photo is offline   Reply With Quote
Old 12-14-2017, 04:00 PM   #5
Token11b
You'll have a smell for a little while while the exhaust heat burns off the coatings and other things. It'll go away. I run a gruppe s uel also.
2013 Scion FRS Firestorm- Current mods: Gruppe-S UEL Headers w/overpipe, Perrin intake tube w/drop in filter Perrin 3" catback, OFT stage 2 turn
Token11b is offline   Reply With Quote
Old 12-14-2017, 04:45 PM   #6
rtalich
Nope did not use anything to break nuts loose.
I bought the header used, so no stickers present.
OK will do!! Thanks.
Thanks... I bought the header used so coatings and whatnot should have already been burnt off.
Old 12-14-2017, 05:17 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Get some soapy water and spray it on the exhaust flanges when its cold. Helps to spot leaks since you'll see the suds move.
Did you use all new gaskets and/or RTV?
Old 12-14-2017, 06:38 PM   #8
rtalich
Thanks! That was my plan for this weekend.
I used new gaskets but just received a set of new ones from Grimmspeed I am going to use.
BRZ header install Highweigh BRZ First-Gen (2012+) — General Topics 4 09-23-2016 10:55 AM
UEL Header install Romiikr Engine, Exhaust, Transmission 7 12-21-2015 01:31 PM
Deepest catback you've heard -- but with an uncatted uel header autograph Engine, Exhaust, Transmission 14 05-12-2015 03:40 PM
UEL uncatted Header + OP/FP + Stock CBE Thoughts and anyone else running this? Aztec Engine, Exhaust, Transmission 5 03-09-2015 01:28 PM
Best <$1k uncatted EL header??? M23 Engine, Exhaust, Transmission 30 02-19-2015 01:15 AM
