Old 06-05-2019, 01:34 PM   #1
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
Possible solution for notchy shifting in second
I have been experimenting with an issue a lot of us are experiencing. The less then smooth shift into second gear, especially when the engine is cold.
I noticed a significant improvement when slightly adjusting the plate as illustrated in the picture.
It is a bit of work to tear the interiour apart but it is worth a try. The adjustment was minimal but it seems that the shifter is better positioned to slide into second. I thought I'd share.
Guru Woodman is offline   Reply With Quote
Old 06-05-2019, 01:38 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Thanks, looks like an interesting fix. Why the dashboard strip?
Old 06-05-2019, 02:36 PM   #3
Guru Woodman
I was frantically looking for some strip in the picture lol, the dash was stripped because I was replacing some other parts.
You only need to disassemble the centre console to get access to the metal plate.
Old 06-05-2019, 04:53 PM   #4
gpvecchi
gpvecchi's Avatar
The correct way to adjust it is to put a 1 mm spacer (straight) when 2nd gear is engaged and tighten screws. If it's impossible to shift from 1st to 2nd the spacer has to be reduced to 0.8 mm.
These are the instructions that came with TRD short shifter.
gpvecchi is offline   Reply With Quote
Old 06-05-2019, 05:56 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Official adjustment procedure
Difficult and notchy shifting issues Mrone Issues | Warranty | Recalls / TSB 26 05-06-2019 09:59 PM
TRD quickshifter - still notchy? unsurety Engine, Exhaust, Transmission 2 03-24-2014 12:00 AM
Notchy Shifting Decisis Engine, Exhaust, Transmission 20 02-07-2014 04:36 AM
Now 4th gear is notchy Yruyur Engine, Exhaust, Transmission 38 11-15-2012 09:07 PM
