Old 05-28-2019, 02:57 AM   #1
Phuviano
Drives: FRS RS 2.0 #757
Motul 300 vs stock (transmission and diff oil) in cold climates
So I've done a bit of research, and Motul 300 seems to be one of the favourite oils to use for the transmission and diff. However, pretty much everyone says its not good on colder days. You get a 2nd gear grind. I've never driven my car in the winter, since i only got it 3 weeks ago. So I've never experienced this 2nd gear grind. Plus my car only has 9,000 km's.
So my question is. Does this 2nd gear grind in the winter happen with the stock fluids? if so, is it a bit better with the Motul 300 or not?
I'm not worried about the warmer months of the year, since I've heard good this about Motul 300 being great in warmer weather.
Phuviano is offline   Reply With Quote
Old 05-28-2019, 05:46 AM   #2
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
no issues here but my winters are not as cold as yours. Running 300 Motul
jbsali is offline   Reply With Quote
The Following User Says Thank You to jbsali For This Useful Post:
Phuviano (05-28-2019)
Old 05-28-2019, 07:10 AM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
In New England my first couple shifts into 2nd, (getting onto my main street, rounding the corner...) were smoother but still made noise. After that, it gets up to temp and it's smoother the rest of the time.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Old 05-28-2019, 08:53 AM   #4
StraightOuttaCanadaEh
Wes
It's not bad. I preferred the other one... name escapes me at the moment... but it's discontinued now. I use Redline and it's slightly less grindy than Motul. I would say Redline > Motul > OEM.
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
Phuviano (05-28-2019), qqzj (05-28-2019)
Old 05-28-2019, 12:12 PM   #5
Phuviano
I think you're talking about pentosin.
So do all oils have the grind? Including stock?
Old 05-28-2019, 12:36 PM   #6
Wes
yeah especially early in the life of the car. Mostly gone around 15-20K km. I'm at 50K km, no issues. No grinds unless my fault
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 05-28-2019, 02:01 PM   #7
RayRay88
Drives: 2017 86 860 Special Edition
The grind/crunch can be avoided by just depressing the clutch completely and shifting quick and deliberately into 2nd. It'll still clunk if it's cold. The fluid change won't alleviate that issue. It's just tight tolerances.
300 does feel smoother over all once the drivetrain is up to temp.
RayRay88 is offline   Reply With Quote
The Following 2 Users Say Thank You to RayRay88 For This Useful Post:
Phuviano (05-28-2019), XtremeMaC (06-11-2019)
Old 05-28-2019, 02:17 PM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
So much better than stock here in Vermont with my car. Switching from stock was the best move I could recommend
The Following User Says Thank You to DarkPira7e For This Useful Post:
Old 05-28-2019, 04:42 PM   #9
Phuviano
I'm aware of that. My concern is whether the stock fluid when cold and in the winter time. Is Motul 300 still better than stock fluids when cold.
I'm not concerned about when the fluids are warmed up.
Old 05-29-2019, 12:21 AM   #10
RayRay88
Try reading the rest of the post...
Nothing is going to "solve the cold crunch" because there's nothing to solve.
It's all just tight specs and cold climates.
Be deliberate and careful with the transmission much like you would the engine when it's cold.
Pentosin might make you feel a little better about it but all it's doing is masking the noise slightly.
The good news is the tranny warms up super quick compared to the rest of the powertrain.
Phuviano (05-29-2019), XtremeMaC (06-11-2019)
Old 05-29-2019, 02:19 AM   #11
Phuviano
Alright, that's all i needed to know. Thanks.
I haven't experienced this 2nd gear crunch, because i haven't had the opportunity to drive my car in the winter yet.
Isn't Pentosin discontinued? that's what I've read at least.
I guess I'll do the change to Motul 300 since the 2nd gear crunch is pretty much unavoidable in the winter.
Old 05-29-2019, 07:40 AM   #12
RayRay88
Honestly it's not too bad at all. Literally I feel it for the first 1km of my drive even on the coldest days this past winter where it was hitting -30C.
There are also a ton of other High Performance fluids you can look up, Redline, Royal Purple, AMSOil etc. It really comes down to cost and brand preference to a certain extent. I think regular change intervals and manual driving best practices will do much better for over all transmission/differential longevity.
Old 06-06-2019, 12:45 PM   #13
chipmunk
Drives: _
Pentosin GL-4 MTF is discontinued and replaced by GL-5 MTF
Sent from a potato
chipmunk is offline   Reply With Quote
The Following User Says Thank You to chipmunk For This Useful Post:
Old 06-06-2019, 01:23 PM   #14
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Sent from a potato
You can run that without issues. Don't get hung up on the GL-5 rating. Motul is also GL-5 rated.
Trueweltall is offline   Reply With Quote
Motul Gear Competition 75W-140 in Transmission and Diff JBezugs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 03-18-2018 05:07 PM
Motul Gear Competition 75W-140 in Transmission and Diff JBezugs Engine, Exhaust, Transmission 6 03-15-2018 03:55 PM
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG jfg5067 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 01-18-2016 09:24 AM
Limited Slip diff oil Motul GEAR 300 LS 75W-90 FRSToyota86 Canada Classifieds 12 08-22-2014 12:47 PM
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 07-03-2014 08:06 PM
