Old 03-14-2018, 06:52 PM   #1
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
Motul Gear Competition 75W-140 in Transmission and Diff
Hey guys,
About a month and a half ago I went to a local performance shop to swap out the factory fill of trans and diff fluid for something a bit better (at about 18k kms).
I know that many in the community use Motul Gear 300, so when my mechanic recommended Gear Competition I really didn't think twice about it. He said its his go to recommendation for Subaru's (WRX's, STI's BRZ's and FRSes) and has used it many times in the past so I trusted his word.
Now upon doing more research about it, I am getting worried that I may be doing harm to my trans/diff. Should I flush and fill with a 75W-90?
JBezugs is offline   Reply With Quote
Old 03-14-2018, 07:32 PM   #2
humfrz
Oh, I wouldn't bother. As long as your transmission shifts OK, it should be fine. I don't think your differential cares one way or another.
humfrz
Old 03-17-2018, 10:59 AM   #3
TRAKRAVN
Drives: 2015 Scion FRS - Raven
I use the 75w-140 in my diff but I have an clutch plate LSD and not the stock diff.
TRAKRAVN is offline   Reply With Quote
Old 03-18-2018, 05:07 PM   #4
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Wrong API rating (GL5) and twice as thick as needed. But it's up to you, as far as who you believe about transmission lube specs - some local wrench or the factory.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Motul Gear Competition 75W-140 in Transmission and Diff JBezugs Engine, Exhaust, Transmission 6 03-15-2018 03:55 PM
Motul Gear Competition 75W-140 for differential? Tor Tracking / Autocross / HPDE / Drifting 13 09-11-2016 08:01 PM
Limited Slip diff oil Motul GEAR 300 LS 75W-90 FRSToyota86 Canada Classifieds 12 08-22-2014 12:47 PM
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 07-03-2014 08:06 PM
Transmission fluid blending Redline MTL and Motul Gear 300 okay? imom Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-01-2013 08:03 PM
