Old 03-22-2015, 12:10 PM   #1
jfg5067
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG
Just wondering if anyone else had effects such as this... I changed out both my MT fluid and differential to Motul 300, and went from 29 MPG to 23... Is this just due to a break in period of the new oil? Or just characteristic of this particular oil? Thanks!
jfg5067 is offline   Reply With Quote
Old 03-22-2015, 12:14 PM   #2
stugray
Drives: 2013 GBS BRZ Limited
I saw no change at all in mine. 30 MPG solid.
It's not the oil causing a 20% reduction in your gas mileage
Old 03-22-2015, 01:28 PM   #3
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Tire pressure, driving habits, bad fuel, different weather can all change your MPG, but a bit of oil certainly wont! :P
Mad1723 is offline   Reply With Quote
Old 03-22-2015, 02:08 PM   #4
jfg5067
Just curious, I just checked tire pressures, I did bump up to 8 inch wide wheels and 255-40 tires... But doubt that's going to do that either... And I actually have been driving more conservatively
Old 03-22-2015, 03:36 PM   #5
Chanpion
Drives: 13 FRS Satin
Still running Primacy HPs or something else?
If you're running something else, you've found your problem. The Primacy HPs are low rolling resistance tires.
'Usually' going to a thinner MTF fluid will increase fuel economy.
Chanpion is offline   Reply With Quote
Old 03-22-2015, 05:38 PM   #6
JB86'd
JB86'd's Avatar
Drives: JAWS
Heavier wheel and tire combo can definitely affect MPG...and a non LRR tire too.
Old 03-22-2015, 07:44 PM   #7
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I think this bit of info should have really been in your first post - the gear and differential oil is not really causing your decreased fuel mileage... LOL
That's like someone saying they switched from Exxon to Shell fuel and noticed a decrease in the fuel mileage...then later posting "Oh yeah I also installed a turbocharger system with higher capacity/flow injectors at the same time...." LOL
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 03-22-2015, 09:44 PM   #8
jfg5067
Except looking back, I did my wheels and tires first, and hadn't noticed a difference but had been driving highway only... then did the fluids change and have been driving local+highway... only noticing it greatly now... I am currently on 17x8 Enkei RP03 wrapped in 245**-40-17 Dunlop ZIIs... not LRR, but lighter combo than oem setup.
Old 03-22-2015, 09:48 PM   #9
Mad1723
Mad1723's Avatar
Well, there's your explanation. You're comparing apples to oranges. City and highway driving, low-rolling resistance vs high grip tires.
Old 03-23-2015, 12:00 PM   #10
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
It's the tires. Going from the Michelin Primacys to Bridgestone RE11As brought me down to about 23-24 as well.
n8dog11914 is offline   Reply With Quote
Old 03-23-2015, 10:28 PM   #11
Vracer111
Vracer111's Avatar
Your setup is over 3lbm heavier a corner than stock...with the tires ~6lbm heavier than the stock ones and in the highest performance level for street tire categories (Extreme Performance - which is designed for track use first, street use second.) Physics is physics... I'd easily wager the MOI is higher with that setup than stock, so it will take more energy to accelerate and stop than with the stock setup.
Old 03-23-2015, 11:17 PM   #12
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
You added unsprung weight and increased your rolling resistance.
Result is too be expected. As least you can sleep well knowing nothing is wrong.
PRO86 | STL | LuckyDog
Old 03-24-2015, 12:47 AM   #13
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I noticed there are difference between different brand of gas. I am getting much better fuel economy with Shell V powaaaah.
Muaddib is offline   Reply With Quote
Old 03-27-2015, 08:42 AM   #14
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Tires and wheels over stock will make a HUGE difference. Therein lies your issue.
-mike
AZP Installs is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Have you changed your tranny fluid of your AUTO BRZ/FRS ScionFR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-14-2017 01:14 AM
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 07-03-2014 08:06 PM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 09:04 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
