Good Job Subaru!
Drives: '18 440i GC, '24 CX-50 Meridian
Motul Gear Competition 75W-140 in Transmission and Diff
EDIT: Mods I realized I posted this in the wrong forum, I have now posted it in the maintenance sub forum. Feel free to delete if desired.
Hey guys, About a month and a half ago I went to a local performance shop to swap out the factory fill of trans and diff fluid for something a bit better (at about 18k kms). I know that many in the community use Motul Gear 300, so when my mechanic recommended Gear Competition I really didn't think twice about it. He said its his go to recommendation for Subaru's (WRX's, STI's BRZ's and FRSes) and has used it many times in the past so I trusted his word. Now upon doing more research about it, I am getting worried that I may be doing harm to my trans/diff. Should I flush and fill with a 75W-90?
Fine in both, but you may find reduced mpg and increased notchiness shifting.
Drives: frs
Ultimately it's not what's recommended by the manufacturer. I don't believe it will hurt the car *short term*
Your car, your risk. |
#5 | |
Good Job Subaru!
Noted. I may keep this fill then until my next interval and switch to Gear 300 after that. I haven’t noticed anything out of the ordinary; it is notchier than the stock fluid in the cold (below 5 deg C) when nothing has warmed up, but I double clutch on upshifts and downshifts when the car is cold anyways. Otherwise the shifter feels better than the stock fluid once up to temp. As an aside, I know second gear can be “crunchy” in this car from time to time, but I also get the odd bit of synchro noise when shifting to third as well (fairly rarely, maybe once on a 45 min commute). I had this issue with the stock fluid as well. Does anyone else have this issue?
#6 | |
![]() humfrz |
#7 | |
Good Job Subaru!
Fair enough! I may be doing the same without realizing it...
| Motul Gear Competition 75W-140 for differential? | Tor | Tracking / Autocross / HPDE / Drifting | 13 | 09-11-2016 08:01 PM |
| Changed Diff/MT Trans Fluid to Motul 300 and super low MPG | jfg5067 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 01-18-2016 09:24 AM |
| Limited Slip diff oil Motul GEAR 300 LS 75W-90 | FRSToyota86 | Canada Classifieds | 12 | 08-22-2014 12:47 PM |
| Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. | B-R-Z | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 07-03-2014 08:06 PM |
| Transmission fluid blending Redline MTL and Motul Gear 300 okay? | imom | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 11-01-2013 08:03 PM |
