Old 09-25-2016, 01:10 PM   #1
slow n FuRiouS
slow n FuRiouS's Avatar
Drives: 2015 Halo FR-S 6MT
Coilover flexing issue
Hi, I am having issues trying to figure out why my driver side rear is flexing so much. Does it have something to do with the preload? The ride dampness is even on both sides as I have the same amount of clicks on the top mount damper. It's like all of the weight goes to my driver side rear when I turn or am on uneven ground regardless of the direction. I would appreciate any advice to fix this issue. Thank you in advance.
slow n FuRiouS is offline   Reply With Quote
Old 09-25-2016, 02:42 PM   #2
swarb
1. What coilovers? bought new?
2. How much preload? how did you set it?
3. What is your alignment? Tire air pressures even/good? Height equal? how did you measure height?
4. What do you mean by all the weight goes to driver side rear? What do you mean by flexing?
5. How low are you and do you have stock sway bar end links?
6. Pics of car on both sides?
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
BC COILOVER ISSUE AZOOZ_95 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-09-2014 07:40 PM
BC Racing extreme drop Coilover Issue SmsAlSuwaidi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 06-11-2014 12:18 AM
Stance coilover issue tysoNgwaNg Northern California 18 04-29-2014 11:08 AM
Rear Strut Brace to fix flexing djliquidsteele Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-15-2013 03:16 PM
