Northern California NorCal
Old 04-22-2014, 05:14 PM   #1
tysoNgwaNg
awesome.
tysoNgwaNg's Avatar
Drives: 1994 Toyota Celica, 2014 Scion FRS
Stance coilover issue
Does anyone else run stance Coilovers and whenever the hit like a small bump or anything make a noise? When I go over a small bump or at low speeds I hear like a clicking noise.
tysoNgwaNg is offline   Reply With Quote
Old 04-22-2014, 05:25 PM   #2
darkonion
Habitual Troublemaker
darkonion's Avatar
Drives: 1997 Subaru Impreza, 2014 BRZ
I do on my Impreza. That probably won't be any help. Is it a clicking sound or more of a clunking sound?
darkonion is offline   Reply With Quote
Old 04-22-2014, 05:27 PM   #3
tysoNgwaNg
awesome.
tysoNgwaNg's Avatar
i think it could be more of a clunking sound?
Old 04-22-2014, 05:40 PM   #4
darkonion
darkonion's Avatar
I've found clunking sounds to be due to something loose. With my Impreza, it was usually the big top nut on the coilover or a loose sway bar. I am not too familiar with the BRZ, but I would just check all the nuts and bolts to make sure that they are tight.
Old 04-22-2014, 07:29 PM   #5
whathedunk
Drives: LR BRZ
check your endlinks for play, their endlinks aren't that well made
whathedunk is offline   Reply With Quote
Old 04-22-2014, 09:26 PM   #6
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
I run them and don't hear anything on mine. How long have you had them installed. I've had mine for about 1k miles.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 04-22-2014, 09:27 PM   #7
tysoNgwaNg
awesome.
tysoNgwaNg's Avatar
Installed for about a month. Only about a couple hundred miles.
Old 04-22-2014, 09:54 PM   #8
Shaun Perry
Shaun Perry's Avatar
Go lower newb. 😎
SBD Turbo V2 | OFT Flexfuel Kit; Tuned by Shiv @10psi | Nameless 2.5in. 1-piece OP/FP | Full Custom Center Exit/SS dual tip cat-back exhaust | KateCOOL Oil Cooler | Mishimoto T-Stat sandwhich plate | ACT XT Street Clutch Kit; 10.5lb flywheel | RSR Black-i Coilovers | Rota Torque 17x9 +30 | Bayson R front lip/side skirts/rear spats and rear windshield visor
Shaun Perry is offline   Reply With Quote
Old 04-22-2014, 10:09 PM   #9
buzznasa
LOL PWR
buzznasa's Avatar
Drives: Whiteout FR-S; Scion tC
This is exactly the problem... Endlinks... RevWorks told me the same thing when they installed mine. The rest of the system is pretty good though, especially for the price.
It's not a midlife crisis if you never grow up.
buzznasa is offline   Reply With Quote
Old 04-22-2014, 10:14 PM   #10
Xerious
Xerious's Avatar
Are the noises coming from the front or rear?
My Build
Old 04-22-2014, 10:32 PM   #11
Khalis
Khalis's Avatar
Drives: 2013 Ultramarine 86
Endlinks suck.
Khalis is offline   Reply With Quote
Old 04-22-2014, 10:41 PM   #12
tysoNgwaNg
awesome.
tysoNgwaNg's Avatar
It's more in the front. Sometimes I think I hear it in the rear
Old 04-23-2014, 12:56 AM   #13
ijuliusx
ijuliusx's Avatar
Drives: 2013 Scion FRS (ARGENTO)
we're in the same situation buddy!
had mine for quite some time now..it first started clunking only in the front, i just tightened the top nut and it went away. and sometimes i also get a front/driver side COIL BIND when i turn on a driveway or something.
fronts are barely noticeable now, but now rears are the one clunking all the time and i haven't got the time to look into yet.
ijuliusx is offline   Reply With Quote
Old 04-23-2014, 01:21 PM   #14
tysoNgwaNg
awesome.
tysoNgwaNg's Avatar
I gotta find time to check it. Cause I'm pretty sure everything is tighten.
Stance Super Sport coilover install/review ill roller Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 11-19-2016 07:31 PM
Stance Coilover AT CLEARANCE PRICING! Also Stance LCA!!! THMotorsports.com Brakes, Suspension, Chassis 201 10-02-2015 07:32 PM
Stance Super Sports Coilover Noises illmattic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-19-2014 11:51 PM
Stance coilovers lowering issue Dispect Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-07-2013 12:05 AM
Stance SS coilover settings Dispect Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-05-2013 05:43 AM
