Old 05-19-2019, 09:33 AM   #1
btan219
Drives: DGM 15' BRZ Limited
Question about transmission and rear differential oil
This is for the 2015 Manual Transmission BRZ Limited
I thought there was only transmission oil and rear differential oil? But upon reviewing the manual and their website for maintenance, there’s a lot of different names for them. Are they all the same or are they actually different oils that need to be maintenanced? Also, I've heard the term manual transmission oil, is that another type of oil is is it the same thing as rear differential oil/differential oil?
48k miles service- inspect transmission gear oil
60k- inspect ATF/transmission fluid
72k- inspect transmission gear oil
48k- inspect rear differential gear oil
60k- inspect rear differential fluid
60k- replace rear differential gear oil
https://imgur.com/a/ZafpqP3
btan219 is offline   Reply With Quote
Old 05-19-2019, 09:41 AM   #2
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
You are correct, the components are a transmission and a rear differential. In this case the terms, "fluid" and "gear oil" are interchangeable, however, that's not to say that the fluid/gearoil itself is necessarily interchangeable between the components.
BirdTRD is offline   Reply With Quote
Old 05-21-2019, 02:43 PM   #3
MJones_RB
MJones_RB's Avatar
Motul claims their 300 Gear Oil can be used both in the transmission (manual) and the differential. Most just use Subaru's Differential Oil without any issues.
MJones_RB is offline   Reply With Quote
Old 05-21-2019, 03:00 PM   #4
Chuckable
Drives: 2017 Toyota 86
This has been covered a lot before, and in conflicting ways. Based one the spec called for in the owners manual I went with the below products.
I know many people will sell the Motul as being suitable for both the transmission and differential, but if you ever have a warranty issue with the transmission then the dealer may not be able to get Toyota to cover it unless you can prove you used the proper spec fluid.
Chuckable is offline   Reply With Quote
Old 05-22-2019, 03:13 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Motul 300 is a proper spec fluid.
Old 05-22-2019, 10:47 PM   #6
Chuckable
Here is the research I did before delving deeper into the meaning and spec of GL-3, 4, and 5:
Old 05-23-2019, 12:19 AM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
My decision as well. I don't trust that it's truly safe for the brass. There's no harm in using a straight GL-4, especially when the gearbox requires only GL-3.
Old 05-23-2019, 08:31 AM   #8
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
It's safe for brass in an environment where the brass components are not synchronizer rings. The buffer that coats the yellow metals and protects them will flake off by the inherent action of syncros and in the process, it brings a small layer of the substrate brass itself with it. Just use the correct GL3/4 from the get-go, instead of something that has a bandaid applied to it in an attempt to make it work in the wrong environment.
GL5 in a hypoid gear environment like the rear diff is perfect.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 05-23-2019, 01:21 PM   #9
Ultramaroon
not playing cards
Yes, thanks for expressing that distinction. This is exactly my understanding of the accelerated-wear mechanism. Crispy crust over a soft center is good for M&Ms but not for synchro clutches.
It doesn't help that Motul is both tight-lipped about their formula and use weasel words in their application info. If they were truly confident in their product, I would expect them to use big bold font instead of burying it in small print.
Old 06-16-2019, 09:21 PM   #10
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
For what it's worth, I dropped the trans and diff oils at 12000km and they were very soiled from the break-in period.
I went amsoil synchromesh in the trans because 2nd was tough to get in in cold weather and 75w140 gl5 in the diff.
I just changed again today, 11000km later, went to amsoil 75w90 gl4 in the trans, synchromesh was a bit too thin and brought out the noisy side of the gearbox, the gl4 shifts much smoother and quieted down the box. For the same reason, I went back to dinosaur gl5 in the diff, but what I had on hand was a bit thicker than stock at 80w90. That should hardly make a difference.
Old 06-18-2019, 01:52 PM   #11
Chuckable
This is what the differential drain plug looked like with 20k miles on the OEM fluid.
Old 06-18-2019, 02:10 PM   #12
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Pentosin MTF2 in the trans. 75w-80
Motul 300 in the diff 75w90
I did mine at 40k. Didnt even look dirty. Im now around 53k, trans feels great.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
FS; Brz manual transmission 2k miles. rear Differential sokol Transmission and Driveline 7 07-25-2019 01:12 AM
Magnetic drain plug in both transmission and rear differential? jc7993 Engine, Exhaust, Transmission 19 04-04-2019 12:58 PM
Transmission and rear differential drain plugs: Are they magnetic? Seanzky Engine, Exhaust, Transmission 22 07-25-2018 07:55 AM
Transmission and differential Frsboxer Transmission and Driveline 7 08-29-2016 11:26 AM
Transmission and differential question Frsboxer Engine, Exhaust, Transmission 8 08-28-2015 08:06 AM
