Old 08-26-2015, 03:36 PM   #1
Frsboxer
Drives: 2015 scion frs
Transmission and differential question
I was wondering about valvoline syn power full synthetic 75w-90 for the tranny and diff. The reason I'm asking because I've searched for this in our cars but found nothing with valvoline. Second of all before the haters chime in this stuff is on our shelves in the shop so I was wondering if this is a quality product to put in since it's free to me
Frsboxer is offline   Reply With Quote
Old 08-26-2015, 07:59 PM   #2
Frsboxer
Anyone?
Old 08-26-2015, 09:19 PM   #3
humfrz
Hi ya, Frsboxer ........
I'd suggest you check your car's drivers manual (pages, 347 & 348 in my manual).
If that products fits the specifications, I reckon it would be OK to use.
I understand that Valvoline makes good products.
humfrz
Frsboxer (08-27-2015)
Old 08-26-2015, 09:21 PM   #4
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
As long as it is api-gl5 you should be fine for the dif. The tranny uses api-gl3. Some additives in certain brands of api-gl5 are bad for syncros in the transmission. Just further your research. Better to know the hard facts than go off an opinion on the forums with no backing.
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
The Following User Says Thank You to carbonBLUE For This Useful Post:
Old 08-26-2015, 09:21 PM   #5
carbonBLUE
Reverse Burnouts
http://www.ft86club.com/forums/showp...11&postcount=1
(wont forget you)
2011 Infiniti G37x
Old 08-27-2015, 01:11 AM   #6
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I've used $20/qt redline oils, and I'd put the Valvoline right up there with it, for a fraction of the cost. I had no issues with the GL5 rated 85w140 I used in my last project. The higher sulfur content of the diff fluid can harm brass synchos, but I never experienced any issues using the Valvoline in the transmission. It worked amazing in My RS5F70V and RS6 Aisin units without shifting problems at all.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
Old 08-27-2015, 09:25 AM   #7
Frsboxer
Thank you all for the input I've searched for a valvoline input but couldn't find any anywhere on the interweb. I'll put the valvoline in the diff and get some redline ordered for the tranny.
Old 08-27-2015, 04:58 PM   #8
Frsboxer
What about royal purple syncromax?
Old 08-28-2015, 08:06 AM   #9
Frsboxer
Bump
Transmission and differential Frsboxer Transmission and Driveline 7 08-29-2016 11:26 AM
Can I use Motul 300ls on transmission and differential Argento86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 08-08-2014 06:52 PM
Aftermarket differential (LSD) options for automatic transmission (AT)? dp1 Tracking / Autocross / HPDE / Drifting 44 07-21-2014 04:30 AM
Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-05-2013 05:12 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
