Old 05-10-2019, 03:49 PM   #1
Geex
Camber plate adjustment
Hey,
Lets say I was to mess with my front camber plates and add more negative camber, would it also add more toe ? in or out ?
Geex is offline   Reply With Quote
Old 05-10-2019, 04:20 PM   #2
wparsons
wparsons's Avatar
It'll definitely mess with the toe, IIRC it'll add toe in when you add negative camber.
flickr
Old 05-10-2019, 04:27 PM   #3
Geex
Thanks for the reply, also for example lets say I have 0 toe and 0 camber if I were to add about -3 degrees of camber my toe would change obviously. However what if I zero out the camber again will my toe go back to 0 after messing with the camber ?
Old 05-10-2019, 04:34 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
toe is linked with camber. You can do alignment for -3 camber with wished 0 toe, but you'll need to redo alignment, if reverting.
May i ask what is your planned usage scenario where you might need -3 to/from 0 front camber change frequent enough for proper full alignment to not be an option?
Old 05-10-2019, 04:37 PM   #5
wparsons
wparsons's Avatar
Depends on how precise you care about it being, that could work. The amount of toe in added from 0* to -3* is going to be pretty drastic though, why are you adding all the camber without a proper alignment?
flickr
Old 05-10-2019, 04:45 PM   #6
Geex
The -3 was just an example, I was just trying to see if I could get away with adding a bit of negative camber to the front without needing a proper alignment because the wheel pokes out a bit. (I know I should of dialed this in before getting an alignment)
Old 05-10-2019, 05:17 PM   #7
maslin
Benz Tech
Drives: 2017 BRZ Premium
Is another alignment cheaper than 2 new tires every few months?
maslin is offline   Reply With Quote
Old 05-10-2019, 05:29 PM   #8
strat61caster
strat61caster's Avatar
A few tenths of a degree of camber won't add unreasonable toe to the point where significant tire wear is noticed (like a mark or two on the plate).
Buy a set of toe plates, adjust the toe yourself, they'll pay for themselves after the second adjustment.
ineedyourdiddly
Old 05-10-2019, 05:33 PM   #9
wparsons
wparsons's Avatar
How much is "a bit"? There isn't much point in adjusting the camber then turning it back.
flickr
Old 05-13-2019, 06:38 PM   #10
G-awesome
Drives: 2015 Firestorm Scion FRS
I'm no expert but I think it depends on how much toe is set initially. If the toe angle is high and you increase the camber, then in theory the toe angle will be greater? Correct me if I'm wrong though.
G-awesome is offline   Reply With Quote
Camber adjustment ThatManAnt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 09-04-2014 08:47 AM
camber adjustment SMOKETREES Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-26-2013 05:39 PM
regarding camber adjustment aruxe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-10-2013 02:02 AM
KW V3 camber adjustment olorin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-28-2013 05:46 PM
