Old 05-05-2019, 02:01 PM   #1
Htownzro
Drives: 2017 Toyota 86 860 SE
2017 Toyota 86 front pipe to mid pipe donut gasket
Hello friends,
Last night put a cat back on my car, when I took the stock exhaust off no donut gasket. So when I put my hks cat back on there is also no donut gasket now. Is this a problem? Should I pick one up and slap it on?
Htownzro is offline   Reply With Quote
Old 05-05-2019, 09:00 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
If the HKS exhaust has a donut gasket type flange (instead of a flat 2.5" flange), you'll need it or else you'll have exhaust leaks
EndlessAzure is online now   Reply With Quote
Old 05-05-2019, 10:33 PM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by Htownzro View Post
Hello friends,
You sure it wasn't wedged into the oem catback? maybe check there and see if it some how slipped off and was stuck in the catback piping. If not, you'll need a new donut gasket to prevent leaks.
MS, CSCS, TSAC-F, CPT
Old 05-11-2019, 03:49 AM   #4
Htownzro
I didn't see it, any chance it is like melted on to the front pipe? front pipe to mid pipe looks like it has a little bit poking out with a black tip that looks like the pictures of the donut gaskets and I haven't noticed any leaks yet so I think that's the case
Old 05-11-2019, 09:07 PM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
The a used donut gasket will probably look like it's part of the pipe when you look directly at it. The front pipe flange mating surface should be flat, if it isn't then there is a donut gasket attached.
I took mine off at 20k KM when I did mine and I had to pry it off with a flat nose.
Old 05-11-2019, 10:01 PM   #6
Htownzro
Cool then it was stuck to the front pipe and I have one! Thanks for the help
Front Pipe Gasket Ashleususs Engine, Exhaust, Transmission 5 05-24-2018 08:51 PM
no flange for donut gasket on J2 front pipe k0tkmnd Engine, Exhaust, Transmission 1 06-05-2015 02:04 PM
Front Pipe donut gasket EightSix93 Scion FR-S / Toyota 86 GT86 General Forum 1 06-02-2015 09:02 PM
Front pipe to mid pipe gasket? ryoma Engine, Exhaust, Transmission 6 04-30-2015 12:27 AM
front pipe use donut gasket or not garfull Engine, Exhaust, Transmission 2 12-09-2013 03:20 PM
