Old 04-30-2019, 07:12 PM   #1
jakezitcovich
Drives: Scion FRS
Optimum alignment with aftermarket control arms
I bought a set of Megan Racing lowering springs. When I took it to the dealer to get the alignment they mentioned the excessive camber (around -3 degrees). I bought a set of rear control arms (Billet Racing from FT86speedfactory). I got them aligned again and notice some issues. Not only is there a major decrease in traction (to be expected) but you can feel the tires fighting for grip in any situation causing the car to sway. around sharper turns the TSC sensor goes rapid with the major loss of traction. Is there an optimum setup to help with the traction without completely destroying tires on a daily driven setup?
jakezitcovich is offline   Reply With Quote
Old 04-30-2019, 07:23 PM   #2
i8ur911
Drives: 17 BRZ Series.Yellow
What's the current alignment set up?
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 04-30-2019, 07:26 PM   #3
jakezitcovich
Drives: Scion FRS
I had the alignment set back to factory standards. I’m running 17” Motegi rims with Pilot Sport 4s Tires
Old 04-30-2019, 07:28 PM   #4
i8ur911
Front or rear tires are fighting for grip?
Old 04-30-2019, 07:51 PM   #5
jakezitcovich
Drives: Scion FRS
Rear. I haven’t messed with the front other than the springs
Old 04-30-2019, 08:07 PM   #6
KevlarZN6
Drives: 13 Toyota 86~ 72 Rb26 240z
Most likely your rear toe is off. I had the same issue when I put on coilovers and rear control arms. I recommend getting your car aligned by a shop that knows what they’re doing. Factory specs won’t work well if you’re lowered. Dealer and normal tire shops will align it to OEM specs. I could be wrong but that’s what I concluded when I did my research.
KevlarZN6 is offline   Reply With Quote
Old 04-30-2019, 08:13 PM   #7
i8ur911
Agree.
Adjusting the rear of a "twin" with adjustable rear camber arms is a bit of a pain. When adjusting the toe, the camber moves and when adjusting the camber, the toe moves. So, it takes patience and persistence to get it right.
If the shop didn't provide you with a print out of your alignment (showing before and after), I'd definitely request it.
As mentioned above, you likely need to go to a shop that "had a clue" or actually cares about the quality of work they put out.
Old 04-30-2019, 08:59 PM   #8
bfrank1972
Drives: 2013 FR-S Argento
Folks this is the classifieds section, this probably should be in the suspension discussion area
bfrank1972 is offline   Reply With Quote
Old 04-30-2019, 09:53 PM   #9
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
How much do your springs lower the car? I installed springs earlier this year that dropped the car about 1 inch and went with the most commonly recommend alignment for a daily driven FR-S/BRZ with ~1 inch lowering springs:
Front camber: -2° (maxed out Whiteline or SPC camber bolts should give you somewhere around there)
Front toe: 0
Caster: stock
Rear camber: -1.5° (.5 less toe than the front, so if you had -2.2° up front you'd want -1.7° in the rear)
Rear toe: 1/16 total toe in (helps rear stability)
If you're REALLY serious about your alignment I'd suggest asking the shop if they'll do the alignment with you (or something that weighs as much as you) in the driver's seat. If they do the alignment with no weight in the car then the alignment gets thrown off when you sit in the car. If they do it with you in the car then you're alignment will be perfect when you get in, but that's mostly for hardcore track/autocross people. I double you'll notice a difference on the street.
Face_Plant is offline   Reply With Quote
WTB Aftermarket Rear Lower Control Arms arkanist Want-To-Buy Requests 0 01-22-2019 01:16 PM
Eccentric camber bushings for lower control arms - anyone tried them? Alignment? Nickmann Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 12-20-2018 02:21 PM
wanted: rear control arms, toe arms & trailing arms Turbo Canada Classifieds 0 08-14-2018 12:18 AM
ISC Lower Control Arms and my most recent Alignment NorCalGirl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-27-2014 02:34 AM
Effect of aftermarket rear control arms on toe protpibe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 06-26-2014 03:55 PM
