Old 04-28-2019, 08:24 AM   #1
Akrochik
Drives: Golf TDI for now
Retrofit HID turning on with high beam only
Just installed the morimoto kit, projectors and all. Lights turn on only when I flip the high beams on. Tips to get it working right? Thanks
Akrochik is offline   Reply With Quote
Old 04-29-2019, 03:33 PM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Sounds like the wiring is incorrect.
When you turn on the High Beams, what it's actually doing is sending power to the projector to lay the shield down to not block that part of the projector anymore and let it shine full blast.
Clueless
YamahaR86 is offline   Reply With Quote
Old 05-12-2019, 01:12 AM   #3
Akrochik
My oem input wasn't clicked in all the way. All good now.
Old 05-12-2019, 11:51 AM   #4
andrew4554
Drives: 2015 Scion FRS
lets see some pics of your retrofit!
andrew4554 is offline   Reply With Quote
Turning lamp won't turn on with low beam MarcusDer Issues | Warranty | Recalls / TSB 6 04-01-2019 11:05 PM
HID vs LED Low/High beam along with DLR? xFury Cosmetic Modification (Interior/Exterior/Lighting) 5 12-15-2015 12:15 PM
DRL or high beam or both? jacobzking Cosmetic Modification (Interior/Exterior/Lighting) 5 06-09-2013 04:09 PM
HID and high beam use gatorbushmen Cosmetic Modification (Interior/Exterior/Lighting) 4 04-19-2013 05:56 PM
