Old 04-17-2019, 03:04 AM   #1
kyle32dean
Drives: 2013 Subaru BRZ (silver)
Tach Gone Crazy! Need Help
Hello everyone, I am super new. Just bought my BRZ and this has been a dream car for a long time. It is a 2013 BRZ with manual transmission. The issue I have been having is that about 50% of the time when I start the car up the idle RPM reads really high (like above 4500 RPM). Its idling where it should be but it's reading very high. As I rev it up it continues to climb way past redline and sometimes around to the ODO. I have been doing a lot of research and can't find anyone that is having the same issue. Also the other half of the time when it reads correctly it seems to be dead on. It seems strange that none of the other gauges are messed up at all. IDK what to do. please help.
The first pic is at idle and the second pic is about mid rpm. (obviously not 12,000)
kyle32dean is offline   Reply With Quote
Old 04-17-2019, 09:32 AM   #2
msaikhan
Drives: frs
i'm gonna take a guess on this.
I think the needle is just misaligned or loose from it's mounting.
You can probably take it apart and align the needle.
or just replace it as a whole assembly.
msaikhan is online now   Reply With Quote
Old 04-17-2019, 01:25 PM   #3
humfrz
Welcome to the group!
Oh, I hope the engine isn't running at the indicated RPM?
Assuming it's not, I reckon a tune-er or the dealership should take a look see and see what is whacked out.
Or you could try disconnecting the battery for a minute and hook it back up, to see if the ECU will right itself.
humfrz
Old 04-17-2019, 01:57 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Do the RPMs stay high all the time after you start the car or settle later? Does turning car off/on fix it?
Connect an OBD2 cheap adapter and see if the RPMs show correctly on the adapter vs. the cluster. If that is the case, you probably need a new cluster (ECU output is the right RPMs but the cluster is not delivering them right).
I rule out a misaligned needle because in that case you'd have a faulty RPM reading all the time, not 50% of the time.
If it's not isolated to the cluster, you have an electrical problem and those can be a pita to find.
Old 04-17-2019, 02:22 PM   #5
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
There appears to be tool marks above the speedometer so I would suspect that cluster has been out for one reason or another. You may want to look into that, maybe there's a loose connection back there.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Sportsguy83 (04-17-2019)
Old 04-17-2019, 07:56 PM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Most modern clusters are on the canbus, so it's possible to read internal faults, command the stepper motors and test display segments.
Checking that would be my initial instinct.
Old 06-13-2020, 08:26 PM   #7
N_Raged
Drives: 2019 BRZ Sport-Tech RS
I'm having this issue too. Was just trotting around town when my tach became offset by 3000rpm. Is there anything I can do short of bringing it to the dealer?
N_Raged is offline   Reply With Quote
Old 06-14-2020, 12:23 AM   #8
humfrz
You might disconnecting the battery for a few minutes to see if the UCU will re-set it -
Bubba suggests to rap on the face of the dial with your right hand middle finger's knuckle to see if it's stuck.
(don't be maken fun of Bubba, till you have drank as much beer as he has)
Old 06-14-2020, 01:13 AM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
bubba's info was accurate for the time when the gauges were operated by spinning cables. it's no longer the case though!
humfrz (06-14-2020)
Old 06-14-2020, 01:51 AM   #10
humfrz
Thanks, I'll let him know -
norcalpb (06-14-2020), soundman98 (06-14-2020)
Old 06-14-2020, 10:56 AM   #11
N_Raged
After that happened I kept on shutting down and restarting the car with no success, so I left for dinner. I came back to my car after a few hours and the needle was fine... Maybe it needed a reboot.
The Following 2 Users Say Thank You to N_Raged For This Useful Post:
humfrz (06-14-2020), soundman98 (06-14-2020)
tach starts below 0 aquaman Electronics | Audio | NAV | Infotainment 17 07-01-2016 03:47 PM
Crazy Good Deal or just Crazy MJones_RB BRZ First-Gen (2012+) — General Topics 31 05-06-2016 04:22 PM
HELP: Need Tach Signal!! Lil Abner Electronics | Audio | NAV | Infotainment 39 02-24-2016 09:59 PM
Cant see the top of my tach... MadFRS Scion FR-S / Toyota 86 GT86 General Forum 31 07-29-2013 05:11 PM
BRZ tach to FRS? lavisxice Cosmetic Modification (Interior/Exterior/Lighting) 7 04-01-2013 04:48 PM
