Old 04-13-2019, 11:24 AM   #1
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Is it ok to have different brand of suspension in front and stock rear? (temporary)
Is it possible to temporarily run 2 camber-adjustable coilovers in the front, and 2 stock struts in the rear with camber-adjustable lower control arms? Just for a few hundred miles to get to work, while a whole new kit makes its way here? As long as the rear ride height lines up with the front?
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 04-13-2019, 11:37 AM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I don't know of any coilovers that aren't a significant drop, so you are more likely to scrape the front bumper. Also, it would probably understeer quite a bit. I guess as long as you drive like your grandma is in the car it should be fine. Why not just wait for the kit before doing anything?
The Following User Says Thank You to Spuds For This Useful Post:
Lakitu (04-13-2019)
Old 04-13-2019, 12:30 PM   #3
norcalpb
norcalpb's Avatar
Yeah that’s fine just don’t go crazy.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
Lakitu (04-13-2019), strat61caster (04-14-2019)
Old 04-13-2019, 01:08 PM   #4
Lakitu
Lakitu's Avatar
Thanks, just need to get to work monday and tuesday, parts not coming in til wedsnesday. The car is really difficult and concerning to drive in its current state and its because of 1 seized coilover in the rear that can no longer be adjusted. I figure with the LCA in the rear, it won't quite be an exact stock ride height and I'll have less of a threshold to try and have the front match the rear.
The Following 2 Users Say Thank You to Lakitu For This Useful Post:
Spuds (04-13-2019), strat61caster (04-14-2019)
Old 04-13-2019, 01:16 PM   #5
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
It'll be totally fine. The handling will just be weird. Take it easy or better yet take it to an empty parking lot and see how it handles at the limit.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
Old 04-14-2019, 06:11 PM   #6
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I have driven around for a month with stock fronts and slammed rear end while my fronts were being re-built and had no issues apart from a comfortable front end and lots of clearance!
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Rear Suspension Clunking, front suspension groaning Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-14-2018 07:10 PM
SOLD!! Brand new Winmax W2(Front + Rear) + Brand new Centric Rotor (Fronts only) Alltezza Brakes, Suspension, Chassis 5 07-03-2018 07:13 PM
KW V3 front and Stock Suspension Rear = Most comfortable ride ever? frsdiy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-27-2015 03:21 PM
18x9.5 et 40- temporary on stock suspension? spacers? mkivalex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-25-2014 08:36 AM
