Old 08-14-2018, 12:53 PM   #1
Butterballz
Drives: Black FRS
Rear Suspension Clunking, front suspension groaning
Sorry in advance for the length of the post.
Parts:
Fronts - Bilstein B8, Tarmac Springs, Raceseng Cascam, Racerx Endlink and Tie Rod, Perrin steering rack lockdowns, camber bolts.
Rears - Verus LCA, Racerx Endlinks and toe arms, Bilstein B8, Tarmac Springs, Whiteline Subframe and Diff inserts.
Problem:
Front - Hear a groaning noise while turning to the right while at a complete stop or low speed (going reverse turning steering wheel right). Like friction noise. Happens as the same place when turning right. Can feel possible vibrations through the pedals when it happens. Did not notice it before when I first installed it. Pretty sure it's not the tires making the noise.
Rear - I hear clunking while braking to slow down or going over bumps at low speed. Not a single clunk but multiple. Hear it rarely if ever while accelerating and cruising. Not sure if it was there when I first installed the parts but now it's quite noticeable. Might have gotten progressively worst over time. Quite annoying. Don't mind if it is normal but if it is not, got to figure it out.
My toe arms jam nuts did come loose a few times when I first installed it. Probably drove like that for 2 or so months with 4 alignments in between to fix the problem. Has not come loose since the fourth alignment
Actions:
Fronts - Tightened the top nut on the shock.
Rears - Already went under and tightened everything. Adjusted the endlinks so there are no preload or at least I think no preload with suspension loaded. Have not disconnected the endlinks yet but will.
Possible Answers:
Front - Maybe the pillowballs are getting stiff so it grips a bit. Noticed when going lock to lock that the right pillowball does not move the same as the left. The left spins a bit while the right just moves in the direction of the shock if that makes sense.
Rears - Nature of pillowballs. Possible hitting hard enough at the limits of the motion to make noise.
Another answer is the endlinks. The joints on the endlinks easily moves since it is not so stiff like the other parts so as I brake it may move around enough to cause noise as it hits the limits of the range of motion. The joints does not appear to be broken. There is no movement except the intended range of motion of the joint.
at this point. Thanks!
Butterballz is offline   Reply With Quote
Old 08-14-2018, 01:07 PM   #2
strat61caster
strat61caster's Avatar
My Racesengs had the spring perch rub on the camber plate creating a groaning noise during low speed, eventually they created the clearance they needed. If you look up from underneath you might be able to spot where the metal is rubbing.
Rear I'd say either drivetrain lash from the bushings now transmitting the noise or swaybar endlinks. Easy to check the endlinks by removing them.
Camber plate rub:
ineedyourdiddly
Tcoat (08-14-2018)
Old 08-14-2018, 02:45 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
That rubbing seems like error of a bit botched design on raceseng part. Even if it self "fixes" this way, that doesn't look to me as it's how it should be. Even if only resale value due fscked up looks is one to take hit and after rubbing excess off it keeps working normally. BTW, this rub was with which coilovers/what diameter springs/perch and at what camber settings?
Old 08-14-2018, 04:50 PM   #4
strat61caster
I customized my spring perch so I wouldn't blame Raceseng's design.
ineedyourdiddly
Old 08-14-2018, 05:31 PM   #5
Butterballz
Drives: Black FRS
Camber plate rub:
I thought it could be the spring perch but didn't get rubbing noise with -3 camber and I have less now. Didn't notice any scratches on the spring perch/camber plates. Might be tire rubbing the fender. Didn't think to check as my car isn't low. Strange thing is it only happens when I turn the steering wheel to the right at around 2o'clock.
Yea, I got to check the endlinks.
Old 08-14-2018, 07:10 PM   #6
norcalpb
norcalpb's Avatar
Sounds like you have 14 aftermarket spherical bearings in your car, so that’s most likely it.
I have the tarmac springs and they’re super cut up and rusted by the “dead spring” part. Clearly the coils are hitting each other to remove the paint and have them rust. This is probably not it, as my tarmacs don’t make much noise, but look for wear where I am talking about.
Clunking on hard cornering from front suspension Open Loop Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 06-01-2017 08:47 AM
Suspension clunking (i think) BRZ'13 Issues | Warranty | Recalls / TSB 15 09-21-2016 11:53 AM
Rear suspension clunking noise. Help ): dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 09-15-2016 03:09 AM
Clunking in rear suspension toeout Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-21-2015 04:11 PM
rear rattling/clunking suspension noise ceebo Scion FR-S / Toyota 86 GT86 General Forum 8 04-25-2014 10:00 PM
