Drives: jrsc_brz
Let's talk brake pads
What do you use? What are your driving conditions? What do you reccomend?
I'm going to be doing a track day soon and am planning on putting in carbotech xp10 pads for it. If they aren't too loud ill I'll keep them in for dd after. I'll put new fluid in before as well. |
I understand that the stock brake pads are just fine for average driving and an occasional track day.
humfrz |
#3 | |
Drives: 2017 Subaru BRZ Limited
I would not recommend using stock pads on the track at all. It's potentially life-threateningly dangerous, depending on the particular track configuration. The stock brake pads are not intended for the high levels of heat that can be incurred and can literally separate/melt the compound off the backing plate (I've done this accidentally). If you're going on the race track, get appropriate fluid and pads. You can start on the cheaper side, but stock pads are not sufficient or appropriate for track usage. They are perfectly fine for a daily driver. |
Drives: 2014 GT86
I suggest going to forum's Tracking section, or more specific, one of it's stickied thread Track Brake Pad Dsicussion Thread. Info in other threads there also might be of use. What pads might fit best to you, will be most dependent from tires you have and your skills, and to lesser degree if you have forced induction, heavy aero downforce, and if having brake air ducts and if having BBK. Imho another thread here on track brake pads might be redundant.
#5 | |
Senior Misanthrope
If you're going to track and daily your car, there is no real compromise. You will need a set of daily pads, and a set of track pads. |
Drives: Crapcan
I have XP10's and I am not really that happy with them. I can not keep the fronts bedded in. When they get really hot the feel is kind of inconsistent, don't know how else to describe it.
Sarcastic SOB
I use Project Mu 800+ for daily and the occasional track day. Switched to higher rated brake fluid same time. They do squeak when coming to low speed stops but they really love heat generating stops from higher speed to quiet them down for awhile. This car is stored during winter.
#8 | |
TRACKBREAD
How's the dust? |
Sarcastic SOB
Minimal, but there is more than stock I'd say. The key is these pads love heat. It is just tolerable for me or I'd swap in the stock pads for daily. With wider tires, firm coil overs and a supercharger, I felt my brakes need some enhancement to keep up even for semi-daily use..
#10 |
Drives: None
Is my old age getting to me? I swear there's a sticky on this exact topic somewhere...
#11 | |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
#12 | |
Drives: None
#13 |
#14 |
86Cup drivers use and recommend the following.
Pads: Winmax W5 or W6. PMu ClubRacer or 999. CSG-spec C1 Fluid: Winmax RBF. Pmu Gfour-355. Endless RF650 Dailying race pads is fine. You will get used to the dust and noise. Swapping pads is easy so either way is ok. |
| The Following User Says Thank You to mixxxx For This Useful Post: | Tristor (04-09-2019) |
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 06:17 PM |
| Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 01:29 PM |
| Wtb coilovers, brake pads, SS brake lines, engine dress up stuff | IBill4You | Want-To-Buy Requests | 2 | 06-13-2015 04:02 PM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 02:45 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
