Old 04-08-2019, 01:13 PM   #1
HaXx
Drives: jrsc_brz
Let's talk brake pads
What do you use? What are your driving conditions? What do you reccomend?
I'm going to be doing a track day soon and am planning on putting in carbotech xp10 pads for it. If they aren't too loud ill I'll keep them in for dd after. I'll put new fluid in before as well.
HaXx is offline   Reply With Quote
Old 04-08-2019, 01:23 PM   #2
I understand that the stock brake pads are just fine for average driving and an occasional track day.
Old 04-08-2019, 02:09 PM   #3
Tristor
Tristor's Avatar
I would not recommend using stock pads on the track at all. It's potentially life-threateningly dangerous, depending on the particular track configuration. The stock brake pads are not intended for the high levels of heat that can be incurred and can literally separate/melt the compound off the backing plate (I've done this accidentally).
If you're going on the race track, get appropriate fluid and pads. You can start on the cheaper side, but stock pads are not sufficient or appropriate for track usage. They are perfectly fine for a daily driver.
Tristor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tristor For This Useful Post:
humfrz (04-08-2019), smg1138 (04-08-2019)
Old 04-08-2019, 02:12 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
I suggest going to forum's Tracking section, or more specific, one of it's stickied thread Track Brake Pad Dsicussion Thread. Info in other threads there also might be of use. What pads might fit best to you, will be most dependent from tires you have and your skills, and to lesser degree if you have forced induction, heavy aero downforce, and if having brake air ducts and if having BBK. Imho another thread here on track brake pads might be redundant.
Old 04-08-2019, 02:47 PM   #5
kch
Senior Misanthrope
kch's Avatar
You likely won't want to run XP10s for daily. They'll probably squeal and produce a lot of dust.
If you're going to track and daily your car, there is no real compromise. You will need a set of daily pads, and a set of track pads.
The Following 2 Users Say Thank You to kch For This Useful Post:
Tokay444 (04-09-2019), Tristor (04-08-2019)
Old 04-08-2019, 09:08 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have XP10's and I am not really that happy with them. I can not keep the fronts bedded in. When they get really hot the feel is kind of inconsistent, don't know how else to describe it.
Old 04-08-2019, 09:20 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
I use Project Mu 800+ for daily and the occasional track day. Switched to higher rated brake fluid same time. They do squeak when coming to low speed stops but they really love heat generating stops from higher speed to quiet them down for awhile. This car is stored during winter.
Old 04-08-2019, 09:22 PM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
How's the dust?
Old 04-08-2019, 09:51 PM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by Yoshoobaroo View Post
How's the dust?
Minimal, but there is more than stock I'd say. The key is these pads love heat. It is just tolerable for me or I'd swap in the stock pads for daily. With wider tires, firm coil overs and a supercharger, I felt my brakes need some enhancement to keep up even for semi-daily use..
Old 04-08-2019, 10:36 PM   #10
Jamestl
Drives: None
Is my old age getting to me? I swear there's a sticky on this exact topic somewhere...
Jamestl is offline   Reply With Quote
The Following 2 Users Say Thank You to Jamestl For This Useful Post:
Tristor (04-09-2019), wparsons (04-09-2019)
Old 04-09-2019, 12:35 AM   #11
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
You are correct, sir. http://www.ft86club.com/forums/showthread.php?t=8182
BlueWhelan is offline   Reply With Quote
Old 04-09-2019, 12:38 AM   #12
Jamestl
Drives: None
Originally Posted by BlueWhelan View Post
Sorry, my sarcasm must not have come across as clearly as it should have.
Old 04-09-2019, 01:04 AM   #13
BlueWhelan
BlueWhelan's Avatar
Lol. sarcasm or not, its to the threads benefit.
Old 04-09-2019, 01:49 AM   #14
mixxxx
mixxxx's Avatar
86Cup drivers use and recommend the following.
Pads: Winmax W5 or W6. PMu ClubRacer or 999. CSG-spec C1
Fluid: Winmax RBF. Pmu Gfour-355. Endless RF650
Dailying race pads is fine. You will get used to the dust and noise. Swapping pads is easy so either way is ok.
mixxxx is offline   Reply With Quote
The Following User Says Thank You to mixxxx For This Useful Post:
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
