Old 04-01-2019, 08:44 PM   #1
Vtplm
Drives: 13 dgm brz
Metallic grind noise
I just installed kw v3's and got new wheels -- 18x9.5 x43 all around. camber is running at -1.5 rear and lowered to about 13in hub to fender. I noticed that when I take hard turns I've developed a metallic grinding nose in the rear. Looked under the car and noticed that a hose as been worn down on both sides, from I can assume is the parking brake line. Anyone had this issue and know of a fix, though I probably need a new line at this point because of the wear? I cant tell if the bracket connected to the trailing arm is involved or not.
Vtplm is offline   Reply With Quote
Old 04-01-2019, 10:26 PM   #2
humfrz
Welcome, Vtplm to our happy gang -
FYI, the parking brake is a mechanical thing (but I don't know if the cable is inside that hose?)
I'm not sure what I'm looking at in your pictures, so I will pass and hopefully others will be along soon to help you out -
humfrz
Old 04-02-2019, 01:25 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yep you done hella-fucked your car.
101 wheel fitment basics.
But man ol man can it park hard bro!
That aside..... zip ties, wheel spacer would be simple fix. Assuming that cable thingy can be moved.
Proper fix is to sell car or burn it, buy a Honda or what ever 240/Miata you can get.
The Following 4 Users Say Thank You to Mr.ac For This Useful Post:
Tcoat (04-02-2019), Tristor (04-02-2019), wparsons (04-06-2019), x808drifter (04-02-2019)
Old 04-02-2019, 12:43 PM   #4
strat61caster
strat61caster's Avatar
wut
VAG or go home *****
ineedyourdiddly
Old 04-06-2019, 03:05 AM   #5
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
wut
Wut?
Metallic Scratching Noise On Start Up N1rve Issues | Warranty | Recalls / TSB 6 07-31-2018 04:11 PM
Strange metallic vibration noise started dumbforcrumbs Issues | Warranty | Recalls / TSB 1 02-02-2017 08:28 PM
rythmic noise/grind from the back end FRiSson Issues | Warranty | Recalls / TSB 20 11-25-2014 12:09 PM
transmission grind jbailey8748 Engine, Exhaust, Transmission 26 05-18-2014 09:32 PM
Metallic "Clacking" Noise Killians87 Issues | Warranty | Recalls / TSB 9 04-30-2014 12:40 PM
