Drives: 2013 Scion FR-S Auto
Metallic "Clacking" Noise
Wall of Text - Sorry
Hello and thank you for taking the time to read this. First I am at my wits end with trying to get this figured out. Recently I have noticed a metallic "clacking" or taping when I am in drive(automatic) sitting at a redlight. That's how it started out. This problem seemed to be extremely intermittent at first. However I started to notice it more and more. It has not gotten any louder. I really noticed it when I was at a drive though ATM the other day and it seemed to really get after it. I have had it at the Toyota dealership here in Lufkin twice for the issue. I dropped it off this morning at 8:30 am and they called me 11:14 saying again they could not replicate the issue. And assured me that the other FR-S's in the area were having no issues like my car is. So I called a larger dealership in the Lake Charles and Beaumont area asking if they had had any issues. First thing the lady said was a vacuum issue that a PAS case would have to be started by the dealership. I found it odd the lady at the other dealership knew exactly what to do as soon as it left my mouth. I really don't know what to do. I have showed the dealership that my car is at currently a video of the sound the first time I came in with it. Now that I show them the video they say the have to have it replicated to do something about it. Please note that I have had 4 fuel pumps put on this car since I have owned it due to excessive chirping(in order to get them to do that I had to bitch and bitch about problem which they considered a "normalcy". Now that that issue (fuel pump chirping) is fixed they seem like they want nothing to do with my car. Other dealerships will not touch it due to it being an issue that I have already brought it to another dealership for. What are my options? |
Hard to tell without a video, the way you describe it sounds like how I would describe my cars idle, something like this minus the crickets:
[ame="https://www.youtube.com/watch?v=bmooGfYQxms"]Scion frs idle noise - YouTube[/ame] Post up the video you have. |
No bud unfortunately the only way I can describe it is a marble on the side of something thick and metallic. It isn't a fast tick more steady and spaced out when it happens. I have to get it up loaded this evening to YouTube as my work interwebs is ungodly slow :P
#4 | |
Drives: 2013 BRZ Limited AT
Is your car stock, Killians? Maybe the cat and heat shields around the header are the noise? |
#5 | |
#6 | |
#7 | |
Drives: tezla
i also have a weird squeak noise noise like something is loose while driving... its coming from the front end... |
#8 | |
To your first question that video to me represents normal operation of the vehicle. I repeat: this is what the car is 'supposed' to sound like. As for the squeak: is the Air Conditioning or Defroster on? Either will use the A/C pump which when it kicks on gives a squeak. If you're noticing it try turning off the A/C or defrost for awhile, and when you turn it back on listen for the squeak, I know I can hear it the moment I press the A/C button. |
fastest frs in sbg
Drives: sick ass ultramarine frs
U do know that the clanking noise u have there is normal and all frs brz have it due to being direct injection, second ur crickets are pretty bad what kinda fuel do u use
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#10 |
I get the crickets at idle once the car is fully warmed up no matter where I fill up. I've tried BP, Sunoco, Kroger, Shell, and Speedway. Pretty much the same every time. I'm happy letting everyone else be a guinea pig until Toyobaru come up with a real fix.
| DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. | Mikepage | DIY (Do-It-Yourself) Guides | 54 | 10-21-2020 02:34 PM |
| Rear Deck "popping/clicking/tapping/ticking" noise. | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 637 | 04-28-2020 04:55 AM |
| E-Brake issue "clunking noise" when pulling the e-brake while rolling. | Kinzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 06-20-2018 10:14 PM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 06:34 PM |
