Old 03-31-2019, 11:58 AM   #1
armstrom
Drives: none
Options for removing Ecutek license?
I've read several threads on removal of Ecutek tune when returning a car to stock. I have already flashed the matching stock rom supplied by Ecutek but obviously the license remains. Also, Ecutek shows a flash count.. is that something they do on their own (similar to the license key) or is that a standard feature of the ECU that a dealer could see? I have seen some threads indicating the stock ECU doesn't have a flash counter but the threads are old so I'm wondering if the consensus has shifted on that....
I understand if I flash a bone stock factory rom (not one supplied by Ecutek) then the license will be gone. It seems this is usually done with a Tactrix cable and ECUFlash. The only hardware I have available to me is the Ecutek cable and a VCDS cable I used on my VW a few years ago.
Is there any way to flash a stock rom without buying yet another $100+ cable? Does techstream support flashing stock roms without specialized hardware?
Of course I could try to buy a used ECU off Ebay but if it's not a match for my car I'm back to the same problem needing to flash it.
Thoughts? @steve99
Thanks!
armstrom is offline   Reply With Quote
Old 03-31-2019, 05:06 PM   #2
tomm.brz
Drives: brz 2017 hksv2
Ecutek counter is proprietary code so won't show up on other systems
Why you want to totally remove your license? You will lose the license forever and have to buy another one if you want ecutek again
There is a way to remove it with ecutek just renaming the ecutek stock ROM file, but why you would want so if I can ask?
Old 03-31-2019, 06:08 PM   #3
steve99
As above Tombrz is correct
Ill message you how to remove ecutek licience with ecutek, but note it permanent and you loose you licience. If you wanted to use ecutek again you would need to but another licience
If you did swap ecu you could liciely sell the licienced ecu to someone
Old 03-31-2019, 06:19 PM   #4
armstrom
Drives: none
I'm planning to get my P0018 code fixed and trade in the car. I have no use for the ecutek license any more. My concern is that while debugging the cam issue the checksum won't match the stock rom image. If this likely won't be an issue then I can just leave it I suppose.
Old 03-31-2019, 06:54 PM   #5
steve99
Ok part of the cam issue recrification proceedure can involve replacing ecu. If it warantee work then you wont get ecu back, but if its paid work they should return ecu or otger parts to you if requested
Help Removing Front License Plate Bracket immaculate Cosmetic Modification (Interior/Exterior/Lighting) 23 05-08-2018 05:09 PM
What options do I have for removing this rust? btan219 Issues | Warranty | Recalls / TSB 8 05-17-2017 10:19 PM
Options for removing spoiler vroomvroom1 Cosmetic Modification (Interior/Exterior/Lighting) 12 09-26-2016 09:33 PM
Installing stock map with ecutek and removing license Mr Miyagi Software Tuning 4 05-25-2016 05:57 PM
EcuTek options? twincamRob Engine, Exhaust, Transmission 6 09-04-2012 05:14 AM
