Old 05-25-2016, 03:04 PM   #1
Mr Miyagi
Drives: Blue Subaru Brz
Installing stock map with ecutek and removing license
HI, I am getting ready to put a stock map back onto my BRZ using the ecutek license and cable. Can someone guide me to as what the steps would be to do this? Also is there a way to remove the ecutek license from my ecu?
Mr Miyagi is offline   Reply With Quote
Old 05-25-2016, 03:11 PM   #2
jasonojordan
Drives: 2013 satin white brz limited
From my understanding there is not a way to remove the license from the ecu. You load the stock map just like you loaded your custom tune.
jasonojordan is offline   Reply With Quote
Old 05-25-2016, 03:18 PM   #3
Mr Miyagi
ok thanks for the response, also i did not load the custom tune but i cant imagine it will be very difficult. I will give it a shot this weekend.
Old 05-25-2016, 03:26 PM   #4
jasonojordan
nope not hard at all if you have any experience at all with it on any platform.
Old 05-25-2016, 05:57 PM   #5
steve99
Just use the ecutek system to flash the appropiate "stock" map thay is stored in the maps folder with the ecutek software. Flashing one of those 'stock' maps with no ecutek features enabled will also remove the ecu lock.
The ecutek licience is still embedded in ecu, you dont rearly need to remove this and you actually need it if you want to flash with ecutek again.
If you rearly want to remove the ecutek licience and have a 100% byte for byte stock rom you would need to reflash the ecu again with tactrix\ecuflash and use as stock rom from the link below
Help Removing Front License Plate Bracket immaculate Cosmetic Modification (Interior/Exterior/Lighting) 23 05-08-2018 05:09 PM
VIDEO GUIDE - Removing door cards & Installing sound deadening The Sentinel DIY (Do-It-Yourself) Guides 0 07-12-2015 07:10 PM
FS: EcuTek license Stealth Gt86 Audio/Visual, Electronics, Infotainment, NAV 0 04-29-2014 07:56 PM
Do I need to use a torque wrench when installing Grimmspeed front license kit? Meanderchap Cosmetic Modification (Interior/Exterior/Lighting) 3 06-01-2013 07:09 PM
