Old 05-09-2017, 09:45 AM   #1
btan219
Drives: DGM 15' BRZ Limited
What options do I have for removing this rust?
http://imgur.com/a/iBPfO
Bought a used CPO 15' BRZ over the weekend. Noticed a rust spot above the passenger taillight and thought I could remove it myself so I negotiated the price down $500 of what they stated.
Now I'm not too sure if this is something I'd be able to fix myself for less than $500. I sanded down the area but there's more under the paint and I'm not too sure how to proceed from here. There's also a small sized dent (might be hard to see in the picture) around the rust area so maybe there's more rust under there. Or am I just SOL and have to pay to get the whole part replaced? Anyone know around how much that would cost?
btan219 is offline   Reply With Quote
Old 05-09-2017, 01:28 PM   #2
humfrz
hmmmm.......that's in a tough place, however a good PDR person should be able to coax out the dent.
You might consider cleaning it up and then using some touch up paint.
After that, depending on how you feel about that scar ...... you might have to take it into a body shop and have it fixed proper.
That would most likely eat up your $500 ...... and then some.
humfrz
Old 05-09-2017, 01:30 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Totaled.
Part out thread?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 05-09-2017, 01:53 PM   #4
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
wtf..touch up paint will works or...
put a big wing and no body will notice your rust.
FR-Sky is offline   Reply With Quote
Old 05-10-2017, 09:48 PM   #5
ka-t_240
That is going to need actual body work and a respray to be repair properly. It will cost way more than 500.
ka-t_240 is offline   Reply With Quote
Old 05-17-2017, 09:52 AM   #6
afn704
Drives: Red 2016 BRZ
These cars have anti-rust warranty. Bring it to the dealer.
afn704 is offline   Reply With Quote
Old 05-17-2017, 10:51 AM   #7
Anti rust warranty does not apply when damage is involved. A dealer would laugh at anybody bringing that in and trying to claim warranty.
Old 05-17-2017, 01:17 PM   #8
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Yeah you didn't negotiate down near enough for that. I'd ballpark $1500-$2500 for that damage.
That is part of the rear quarter panel and is huge and a giant pain to replace so forget replacing the damaged part. Our cars have been totalled out for nothing other than major rear quarter panel damage.
First, you'll need to remove the light to work on that area. Then see if you can hammer the dent out from the inside. If not, then you gotta bondo the dent away. Next, you gotta sand the damaged area all the way down including the rust so it's all gone.
I'd do the above work myself, mostly because I can but if you can't, expect a shop to charge you $500 for just that. Then the damaged area will still need paint and getting that right has to be left to a professional and most will charge you from $1000 to $2000, depending on how involved painting it will be.
Lynxis is offline   Reply With Quote
Old 05-17-2017, 10:19 PM   #9
alan.chalkley
Drives: 4wd zooks
A good PDR guy can do an external glue pull on the dent.
Then primer,paint,clear coat it.
alan.chalkley is offline   Reply With Quote
Options for removing spoiler vroomvroom1 Cosmetic Modification (Interior/Exterior/Lighting) 12 09-26-2016 09:33 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 04:15 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
