Old 06-03-2014, 08:20 PM   #1
immaculate
immaculate's Avatar
Drives: 2017 Audi S3
Help Removing Front License Plate Bracket
I recently moved to PA and now get to take advantage of one of it's few redeeming qualities: being able to legally run without a front license plate. However, I'm stumped on how to remove this bastard:
The hex bolts just seem to spin when using a socket wrench. I tried prying it a bit from behind while using a wrench with no luck either. It's entirely possible that whatever genius installed this at the dealership could have stripped it. It appears to be impossible to reach up behind the mustache since the front bumper bracing is back there.
Am I missing something, or did Subaru really make it necessary to remove the front bumper to uninstall a simple plate bracket? Thanks in advance.
immaculate is offline   Reply With Quote
Old 06-04-2014, 02:09 AM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
It's most likely bolted on. I have the front plate kit (uninstalled) since most dealers don't install it by default unless customer wants it installed.
aznatama is offline   Reply With Quote
Old 06-04-2014, 03:11 AM   #3
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
There could be plastic tabs like the rear license plate. Maybe be able to take the under panel off and stick your arm up there? I haven't taken off the under panel yet, but it might be worth a try.
slicktop is offline   Reply With Quote
Old 06-04-2014, 03:56 AM   #4
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
I have the same problem, the 2 10 mm bolts just keep spinning. Maybe have to remove the front bumper ? curious to know how to remove it as well
ucsmfu is offline   Reply With Quote
Old 06-04-2014, 09:50 AM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
The install kit (which I ignored - I used the magnet trick) contains rubber fittings with a brass threaded insert - I believe these simply mushroom behind the bumper cover to keep things in place, but that explains why the bolt just spins. You'll need to get behind and grab the rubber so it doesn't spin.
You'll have a pair of ~1cm holes if you remove this.
Old 06-04-2014, 10:07 AM   #6
dan_k
Drives: 2014 BRZ
cjd is correct. You will have to get behind the bumper somehow and hold the rubber inserts with pliers or something similar and then loosen the hex. Good luck.
dan_k is offline   Reply With Quote
Old 06-04-2014, 10:16 AM   #7
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Given the fact that you will now have 2 unsightly holes in your bumper when you remove the plate mount, you might want to consider keeping the mount and putting a Subaru or STi plate on it. I wonder if this would cleanly cover the holes?
http://www.fastwrx.com/collections/m...neous-exterior
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 06-04-2014, 10:31 AM   #8
immaculate
immaculate's Avatar
Thanks! That's what I suspected and feared. What a ridiculous design by Subaru. I don't think it's possible to reach back there with the bumper still attached.
Old 06-04-2014, 10:33 AM   #9
immaculate
immaculate's Avatar
I was considering filling the holes and then wrapping the mustache in a black vinyl, as close to OEM as I can get.
Old 06-05-2014, 12:17 AM   #10
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
will u just keep it on ?
let me know if u figure a way to remove it. I was planning on doing the same thing, filling the holes with bondo and then vinyl wrapping it
Old 06-05-2014, 07:09 AM   #11
immaculate
immaculate's Avatar
I still plan on vinyl wrapping it. Just need to find the time to take the bumper off first. I'll update this thread detailing how to remove that bracket. I'm sure it's not rocket science, but I was surprised there was no info on it, hopefully I can help someone out. I still can't believe Subaru made something so simple such a pain in the ass.
Old 06-06-2014, 07:22 PM   #12
chris wallace
Drives:
I had the same issue and ended up trying for hours before this post was made. I ended up calling the service department at dealer in Ohio who told me about the rubber rivets or whatever and said I should just be able to pull the bolts out with pliers but it doesn't feel like the bumper cover has any give..
Like it would just tear giant holes in the plastic so I gave up and just cut the bracket of and have been driving around with two irritatingly bright aluminum screws in my bumper just begging to come out.
I can't wait to find out more on how to get rid of these hideous things.
chris wallace is offline   Reply With Quote
Old 06-06-2014, 08:22 PM   #13
Lavalover
Drives: 2014 FR-S Monogram Hot Lava
Flat black paint is your friend.
Lavalover is offline   Reply With Quote
Old 08-11-2014, 12:33 AM   #14
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
I'm also trying to do this. I'm actually gonna go to the dealership tomorrow and demand them to remove it themselves.
ShibaYuki is offline   Reply With Quote
DIY - BRZ OEM Front license plate mount/bracket no-drill installation shiumai DIY (Do-It-Yourself) Guides 97 06-03-2021 12:11 AM
OEM Front License Plate bracket installation mwy23 Northwest 13 12-25-2013 04:50 PM
WTB: BRZ OEM Front license plate mount bracket KayoTrap Canada Classifieds 7 10-01-2013 02:08 AM
Frs Cap and OEM Subaru Front license plate bracket Xdragonxb0i Miscellaneous 1 01-16-2013 12:25 AM
USA front license plate mounting? Slimline bracket mount.. Help across the world :P WTF Scion FR-S / Toyota 86 GT86 General Forum 32 08-23-2012 07:25 AM
