Old 03-11-2019, 07:35 PM   #1
Bookies
Drives: 2013 FRS
Cam Tower Leak
I just got a 2013 FRS and the first thing I did was take it to the dealer and have them start the valve spring recall (maybe a mistake). They just called and said my cam towers are leaking and want to charge me $500 to have it fixed. I tried searching the forums but couldn't find much info on this. Should I pay them to fix it or is it not worth it?
Bookies is offline   Reply With Quote
Old 03-11-2019, 07:56 PM   #2
fika84
fika84's Avatar
Have them send you pictures or something... I'm not even sure what they're referring to with the FA20.. I just tore my engine completely down and the only thing I can think of that they're talking about would be a cracked aluminum plate or cover. All of the plates/covers go together with sealant which they have to redo when they replace the valve springs...
fika84 is offline   Reply With Quote
Old 03-11-2019, 09:06 PM   #3
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Whacky terminology. "Cam Towers" uh, wut?
Who's that when he's at home?
Did you inspect the engine before purchase?
Was it dripping oil then?
Pics from the suspect dealer or GTFO.
Old 03-11-2019, 09:17 PM   #4
Ecki
Drives: 2013 FRS
Just reiterating what they told me. They are closed now and it wasn't leaking anything when I bought it or brought it into the dealer. I'll ask for pictures first thing in the morning. They are closed now. Thanks for the info.
Ecki is offline   Reply With Quote
Old 03-11-2019, 09:26 PM   #5
bcj
Geo Tyrebighter Esq
bcj's Avatar
Not ticked at you. The dealer trying one on.
Hope you got a hefty discount on a car with an open TSB.
Old 03-11-2019, 09:29 PM   #6
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Cam tower, or known as the cam carrier. The cylinder head design is actually 3 pieces, and the cam carrier is in the middle (holds the cams in place) between the valve cover, and the bottom half of the cylinder head that is bolted to the block (kind of a dumb design if you ask me). The cam carrier is typically sealed with liquid gasket.
My 2016 actually developed a leak on driver side at 45K miles along with the timing chain cover. Warranty covered the fix. However for $500, if they are doing both sides, I'd say that is a good price. It would probably cost thousands if it was a stand alone repair. But for this recall, I think the cams are removed. So perhaps the cam carrier is removed in the process anyway? You might need to confirm that, and if so, you shouldn't be charged.
Si_Chris is offline   Reply With Quote
The Following User Says Thank You to Si_Chris For This Useful Post:
fika84 (03-11-2019)
Old 03-11-2019, 09:39 PM   #7
Ecki
Drives: 2013 FRS
Awesome, I actually found a video of disassembly and I see it now.
I imagine removing that is part of the recall fix though unless they can reach the valve springs by just removing the cams. I'll look into it more and ask them about it. Thanks for the info.
Edit: I just looked through this PDF which explains the recall procedure and looks like removing the cam tower/carrier is not part of the process so I see why they are recommending it gets resealed. Thanks again everyone who helped.
The Following User Says Thank You to Ecki For This Useful Post:
fika84 (03-11-2019)
Old 03-11-2019, 09:49 PM   #8
Si_Chris
Yep, that is it! You can see the liquid gasket right above the exhaust port where it is sealed. As far as removing it, I think some techs might just remove the cam caps like as seen here: [ame]https://www.youtube.com/watch?v=y7qMnojFTsc[/ame], and not the whole cam carrier assembly. Despite if it is removed or not, the labor involved shouldn't be too intense reseal it.
Old 03-11-2019, 09:56 PM   #9
Ecki
Drives: 2013 FRS
I did. 😊
Yep, that is it! You can see the liquid gasket right above the exhaust port where it is sealed. As far as removing it, I think some techs might just remove the cam caps like as seen here: , and not the whole cam carrier assembly. Despite if it is removed or not, the labor involved shouldn't be too intense reseal it.
Yeah, I found in the recall procedure from Toyota that there is no call to remove the cam carrier so I see why they are wanting to charge to fix it now. Thanks again.
Old 03-11-2019, 10:00 PM   #10
bcj
Geo Tyrebighter Esq
bcj's Avatar
The more I inspect the engine drawings, I'm suspecting more than one person on the design team are steampunks.
Some seriously baroque mechanical decisions.
I started out doing exploded diagrams for jet engines.
If you threw an FA20 at the wall, it wouldn't stick, unless you used a catapult.
The Following 2 Users Say Thank You to bcj For This Useful Post:
fika84 (03-11-2019), soundman98 (02-12-2021)
Old 03-12-2019, 10:14 AM   #11
fika84
fika84's Avatar
I was totally thinking they were referring to something overthe camshafts... towering over if you will
Old 03-12-2019, 10:15 AM   #12
fika84
fika84's Avatar
I was totally thinking they were referring to something over the camshafts... "towering over" if you will
Old 03-12-2019, 10:59 AM   #13
ermax
ermax's Avatar
Here is a diagram:
Old 02-11-2021, 03:39 AM   #14
subiedoobie1994
Drives: 2017 Subaru Brz
A year late, I know. But anyway, for the valve spring recall the cam carrier is coming off, like, for sure. When I do it, I don't do it any other way. Why they want to charge you for resealing it if that is indeed what is leaking, I do not know. I hope you looked further into that. The timing chain cover, rocker cover (valve cover), and cam carrier are coming off and will have to be resealed anyways... which, by the way, if you have the infamous timing cover leak recently after this is done then I'd take it back to them and tell them to reseal it. Free. The next thing to come off is the cylinder head, and you're not leaking oil there.
subiedoobie1994 is offline   Reply With Quote
The Following User Says Thank You to subiedoobie1994 For This Useful Post:
Oil Leak Adamf220 Issues | Warranty | Recalls / TSB 11 05-04-2018 03:51 PM
Oil Leak Brz_racer Engine, Exhaust, Transmission 22 07-17-2017 05:28 PM
Oil leak GsxrMe Forced Induction 4 12-18-2015 09:23 PM
Oil leak. ohnoitsthefuzz Issues | Warranty | Recalls / TSB 2 03-23-2015 02:31 AM
Strut Tower Bar VS Strut Tower Brace norcalpb BRZ First-Gen (2012+) — General Topics 8 10-23-2014 11:31 PM
