Old 12-15-2015, 02:47 PM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Oil leak
I found an oil leak that just won't stop dripping. Its not much but enough that it drives me crazy.
The T used to hook put the factory oil pressure to the oil feed has a non stop leak and i want to remove the T entirely. I've seen people use the Subaru OEM Oil Galley Plug with an AN Male to NPT Male.
The oil line looks long enough to relocate the oil feed but I just need someone to review my parts list.
I'm using Full Blown Motorsports turbo kit.
http://www.rallysportdirect.com/shop...FYUWHwodKzgOlw
Russell 660420 - Russell AN Male to NPT Male Adapter Fittings
http://www.jegs.com/i/Russell/799/66...Fc4XHwod_1YJvw
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 12-15-2015, 07:08 PM   #2
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Yea that's what we did, I don't have the FBM kit, same concept though, however if you are running a precision Ball Bearing turbo, I would urge you to run a -3AN feed line. If it is not a precision ball bearing turbo then carry on. Make sure to use some RTV? (Gray silicone shit) on the threads that go into the block.
Also, don't hesitate to call LJ @FullBlown he is an extremely patient guy!
This is how it is on mine http://screencast.com/t/wRSmVsM7fN6
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 12-18-2015, 08:14 AM   #3
GsxrMe
GsxrMe's Avatar
Thanks. Go to find out there is a seal/washer that is crushed between the plug and the block and I have that on order to, should be here today.
I also want to install check valves on the brake booster and evap. I see a lot of people are doing it but no one is listing parts. I give somebody business if they could point me in the right direction.
2014 Subaru BRZ
Old 12-18-2015, 08:20 AM   #4
FRS Justin
Drives: 2013 Asphalt FRS
Outfront Motorsports makes a 1 piece stainless unit that will keep you from having another connection stainless oring seal I have 0 problems with mine since install pushing over 120 psi at times
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-18-2015, 08:23 PM   #5
GsxrMe
GsxrMe's Avatar
Jesus, That was such a pain in the ass with a turbo blocking everything. Getting the oil pressure sensor back in and tight was time consuming. The new barb next to the AC was easy. I didn't even have to remove the AC compressor. Check Valves was all in-stock at Advanced Auto Parts. cut, slip, tighten clamps & done.
So far everything looks dry.
Now i'm waiting on the next project of parts to come in. "Mishimoto" 2015 WRX oil cooler and Subaru WRX factory oil/water heat exchanger. I'm going to have to fab a bracket in front of the intercooler or something. Not sure yet.
2014 Subaru BRZ
Gas Leak? Fuco Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-07-2022 09:40 AM
Yet another oil leak.... Astroboy Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 09-24-2015 01:02 AM
oil leak ! frsqc Issues | Warranty | Recalls / TSB 5 07-01-2015 07:08 PM
Help - oil leak tlim Engine, Exhaust, Transmission 4 04-10-2015 08:40 AM
Oil leak. ohnoitsthefuzz Issues | Warranty | Recalls / TSB 2 03-23-2015 01:31 AM
