Old 04-28-2018, 03:04 PM   #1
Adamf220
Drives: 2013 frs
Oil Leak
Hi I have a 2013 FR-s and was doing some work to it and i noticed that under the passanger side of the motor it is leaking quite a bit of oil. Was just wondering if this was a common issue and what the cause might be. There is no oil on top of the motor its all on the bottom so its gotta be coming from somewhere down there.
Adamf220 is offline   Reply With Quote
Old 04-28-2018, 03:11 PM   #2
whataboutbob
AutoX-10/10ths every run
Normally they seem to leak near the water pump on the driver's side due to a poor seal on the timing chain cover. I suspect your source is the timing chain cover seal as well, but on the passenger's side. I'd clean up all of the oil off the motor and drive it for a day or so. You should be able to localize the source of the oil leak at that point.
Build thread:Here
Old 04-28-2018, 05:26 PM   #3
ls1ac
ls1ac's Avatar
X2
You can use almost any degreaser but finish up with brake cleaner to dry the area.
Check frequently.
Old 04-29-2018, 10:31 AM   #4
gravitylover
My timing chain cover leak was on the passenger side. It was nowhere near as severe as this but it dripped onto the header and smoked terribly when the car was stopped.
Old 04-29-2018, 11:48 AM   #5
Here are the most common leaks, what cause them, and what to do o fix them
http://www.ft86club.com/forums/attac...1&d=1413834741
Old 04-29-2018, 12:20 PM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Is it just me, or is one of those pictures of an AWD Subaru model...
Old 04-30-2018, 01:38 PM   #7
Adamf220
Drives: 2013 frs
Yea it was leaking on to the header as well. Ill Clean it up and see if i cant find a specific spot that its leaking but i cant drive the car currently hopefully in a couple days.
Old 05-02-2018, 08:47 PM   #8
Decep
Drives: 2013 FR-S Series 10
might clean it up and add some uv dye to your crankcase.
Old 05-04-2018, 11:47 AM   #9
Adamf220
Drives: 2013 frs
So I cleaned it up and it sat for a few days and now you can tell right where it is leaking. Is this still the timming chain cover or is this coming from somewhere else?
Old 05-04-2018, 01:06 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
Old 05-04-2018, 01:14 PM   #11
whataboutbob
Is there any evidence of it running down the side of the motor before it accumulates in a drip? Or, is it just accumulating in a drip where the picture shows?
Build thread:Here
Old 05-04-2018, 02:51 PM   #12
Adamf220
Drives: 2013 frs
No sign of it leaking down from somewhere just coming out where i pictured it
Oil Leak Brz_racer Engine, Exhaust, Transmission 22 07-17-2017 04:28 PM
Oil Leak? Tofu-86 Forced Induction 3 09-23-2016 03:47 AM
Oil leak GsxrMe Forced Induction 4 12-18-2015 08:23 PM
Help - oil leak tlim Engine, Exhaust, Transmission 4 04-10-2015 08:40 AM
A/T Pan leak goke186 Issues | Warranty | Recalls / TSB 0 04-15-2013 10:31 PM
