Drives: Car
Rainy day rotors
Do drilled or slotted rotors help with wet weather braking? I usually ride my brakes prior to hard braking and every once in a while just cruising along as is. It's a little distracting but beats mashing the brakes and having nothing happen for a few seconds. Most of my road going play time in the summer varies between damp and wet roads.
Drives: 2017 Subaru BRZ Limited
What are you doing where nothing happens for a few seconds? I don’t think rotors will help you, but you need to make sure your brake fluid is in good condition and your brakes are bled properly. If you need improved braking performance try better brake pad compounds.
What brake pads are you using right now? |
Drives: Car
Vacuum mode to the seat engages when nothing happens...lol. I mash the brakes harder until they grab. Usually I pre-emptively ride them to dry them off. Only happens in certain spots where road is covered in standing water or pooled up in the frost heaves. Pads are stock performance package. Brakes are amazing to me when its dry out.
Country Boy 4 Life
You could be hydroplaning a bit, what tires are you driving in pools of water?
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Ultramaroon (03-03-2019) |
Definitely can be improved by better pads and also potentially better tires. Leonardo might be onto something with the hydroplaning aspect. Is anything else affected in the wet, or just braking? What tires do you have
| The Following User Says Thank You to Tristor For This Useful Post: | Leonardo (03-03-2019) |
ProCrastinationConsultant
i've never noticed any significant difference in braking application from dry to wet--still running the oem solid rotors/pads currently. for my use, the only reason i want to upgrade is aesthetics.
there's some theory that slotted rotors wipe the pad for a constantly fresh pad material, and many people use this for more consistent braking performance contrasted to solid rotors that can glaze the pad. but if the pad is saturated with water, a new, but still wet part of the pad isn't going to make it any different. but drilled rotors are a waste of money in all but the most tangential extreme circumstances. the theory when the pads/rotors are super heated, gases are created between the pad and rotor, and it can prevent the pad from making contact with the rotor. the theory is that the drilled holes allow those gasses to escape, allowing the pad to make contact and stop the car. the reality of this is the gases are only created at temperatures that would boil oem-spec brake fluid, so by that point, you've already at least upgraded to better quality pads and fluids, but realistically, would understand the more extreme braking requirements of the situation would require an entire braking system upgrade with larger calipers, rotors, stainless lines, different fluid, etc..
Because compromise ®
Drives: Red Herring
The best solution would be to have a set of wet weather rotors and dry weather rotors.
| The Following 5 Users Say Thank You to Captain Snooze For This Useful Post: | Apoc (03-03-2019), D_Thissen (03-03-2019), ermax (03-04-2019), mistople (03-03-2019), Ultramaroon (03-03-2019) |
#8 | |
i'm hoping to progress to one car per day, with some extra allotments for wet/dry days.
#9 | |
Drives: Red Herring
*I'm not sure if that is irony or not.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | soundman98 (03-03-2019) |
#10 |
Drives: Car
It hydroplanes in a few spots. I'm pretty used to that. Definately the brakes, not tires. 90% tread, pilot sport as3+. I have a similar issue right after leaving a car wash. I have a good habit of tapping/ riding brakes so I suppose I'll just keep doing that.
#11 |
Drives: Car
I'll send another email to my parts supplier and see if they get back to me this time. Pads...Mmmmk. Thanks folks.
#12 |
Drives: Crapcan
This thread has me going
![]() Drilled and slotted rotors are unnecessary. Wet or dry you have more braking power then traction. Never a reason to ride your brakes. |
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#13 |
[insert cool phrase here]
Drives: BRZ Premium
Drill slotted rotors do the same exact function as a solid rotor. Only slightly less surface area.
In wet conditions it's null. Due to simple centrifugal force. Like others said, get better pads
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#14 |
Drives: Car
You guys are great! Thank you all!
| Rainy weekend, drive carefully | doggieboy09 | Northern California | 4 | 02-10-2014 03:42 PM |
| Rainy Day Hooning With A Local FRS And New VR Rareness!! | vividracing | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 03-01-2013 12:21 PM |
| This car hates winter & rainy season? | tintumz22 | Issues | Warranty | Recalls / TSB | 12 | 11-17-2012 04:36 PM |
| a rainy day at gingerman | sickmint79 | Great Lakes | 5 | 10-31-2012 10:58 PM |
