Old 03-02-2019, 10:10 PM   #1
remhex
Drives: Car
Rainy day rotors
Do drilled or slotted rotors help with wet weather braking? I usually ride my brakes prior to hard braking and every once in a while just cruising along as is. It's a little distracting but beats mashing the brakes and having nothing happen for a few seconds. Most of my road going play time in the summer varies between damp and wet roads.
remhex is offline   Reply With Quote
Old 03-02-2019, 10:28 PM   #2
Tristor
Tristor's Avatar
What are you doing where nothing happens for a few seconds? I don’t think rotors will help you, but you need to make sure your brake fluid is in good condition and your brakes are bled properly. If you need improved braking performance try better brake pad compounds.
What brake pads are you using right now?
Tristor is offline   Reply With Quote
Old 03-02-2019, 10:38 PM   #3
remhex
Drives: Car
Vacuum mode to the seat engages when nothing happens...lol. I mash the brakes harder until they grab. Usually I pre-emptively ride them to dry them off. Only happens in certain spots where road is covered in standing water or pooled up in the frost heaves. Pads are stock performance package. Brakes are amazing to me when its dry out.
Old 03-02-2019, 10:53 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
You could be hydroplaning a bit, what tires are you driving in pools of water?
I LIKE TIRES!
Ultramaroon (03-03-2019)
Old 03-02-2019, 11:02 PM   #5
Tristor
Tristor's Avatar
Definitely can be improved by better pads and also potentially better tires. Leonardo might be onto something with the hydroplaning aspect. Is anything else affected in the wet, or just braking? What tires do you have
The Following User Says Thank You to Tristor For This Useful Post:
Leonardo (03-03-2019)
Old 03-02-2019, 11:04 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
i've never noticed any significant difference in braking application from dry to wet--still running the oem solid rotors/pads currently. for my use, the only reason i want to upgrade is aesthetics.
there's some theory that slotted rotors wipe the pad for a constantly fresh pad material, and many people use this for more consistent braking performance contrasted to solid rotors that can glaze the pad. but if the pad is saturated with water, a new, but still wet part of the pad isn't going to make it any different.
but drilled rotors are a waste of money in all but the most tangential extreme circumstances. the theory when the pads/rotors are super heated, gases are created between the pad and rotor, and it can prevent the pad from making contact with the rotor. the theory is that the drilled holes allow those gasses to escape, allowing the pad to make contact and stop the car. the reality of this is the gases are only created at temperatures that would boil oem-spec brake fluid, so by that point, you've already at least upgraded to better quality pads and fluids, but realistically, would understand the more extreme braking requirements of the situation would require an entire braking system upgrade with larger calipers, rotors, stainless lines, different fluid, etc..
Old 03-02-2019, 11:19 PM   #7
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
The best solution would be to have a set of wet weather rotors and dry weather rotors.
The Following 5 Users Say Thank You to Captain Snooze For This Useful Post:
Apoc (03-03-2019), D_Thissen (03-03-2019), ermax (03-04-2019), mistople (03-03-2019), Ultramaroon (03-03-2019)
Old 03-02-2019, 11:36 PM   #8
soundman98
soundman98's Avatar
i prefer to have a wet weather car, and a dry weather car.
i'm hoping to progress to one car per day, with some extra allotments for wet/dry days.
Old 03-03-2019, 12:04 AM   #9
Captain Snooze
Drives: Red Herring
Seriously*, if you are going to that much trouble, you really should have a cloudy day car too.
*I'm not sure if that is irony or not.
soundman98 (03-03-2019)
Old 03-03-2019, 12:14 AM   #10
remhex
Drives: Car
It hydroplanes in a few spots. I'm pretty used to that. Definately the brakes, not tires. 90% tread, pilot sport as3+. I have a similar issue right after leaving a car wash. I have a good habit of tapping/ riding brakes so I suppose I'll just keep doing that.
Old 03-03-2019, 12:35 AM   #11
remhex
Drives: Car
I'll send another email to my parts supplier and see if they get back to me this time. Pads...Mmmmk. Thanks folks.
Old 03-03-2019, 12:38 AM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This thread has me going
Drilled and slotted rotors are unnecessary. Wet or dry you have more braking power then traction. Never a reason to ride your brakes.
NoHaveMSG is online now   Reply With Quote
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
ls1ac (03-03-2019), mistople (03-03-2019), soundman98 (03-03-2019), Tristor (03-03-2019)
Old 03-03-2019, 01:28 AM   #13
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Drill slotted rotors do the same exact function as a solid rotor. Only slightly less surface area.
In wet conditions it's null. Due to simple centrifugal force.
Like others said, get better pads
Old 03-03-2019, 01:56 AM   #14
remhex
Drives: Car
You guys are great! Thank you all!
Rainy weekend, drive carefully doggieboy09 Northern California 4 02-10-2014 03:42 PM
Rainy Day Hooning With A Local FRS And New VR Rareness!! vividracing FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 03-01-2013 12:21 PM
This car hates winter & rainy season? tintumz22 Issues | Warranty | Recalls / TSB 12 11-17-2012 04:36 PM
a rainy day at gingerman sickmint79 Great Lakes 5 10-31-2012 10:58 PM
