Old 02-05-2019, 07:28 AM   #1
kev0
Drives: '14
Automatic Transmission Fluid Change?
What fluid do you guys recommend for AT? I'm at 69k and the owner's manual calls for the ATF to be changed at 60k so I'm a bit behind on schedule.
I'll be taking the car to a shop because changing the ATF is apparently a big PITA. I'll be getting it changed and not flushed (is there a difference?) and I'm afraid and don't know where to take it to get serviced because it seems like a big job and I don't want anyone to mess up.. would a dealership be a safe place to take this? I heard that you have to shift gears multiple times to drain the fluids completely.
kev0 is offline   Reply With Quote
Old 02-05-2019, 11:28 AM   #2
mrg666
pessimistic skeptic
mrg666's Avatar
I would just go to dealer for that
Old 02-05-2019, 11:30 AM   #3
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Use only Toyota OEM AT fluid. Do not flush, only drain and fill. Flushing can cause more damage such as bending fins in the transmission. The dealership will be able to do it per the manual but at a higher cost.
N1rve
Old 02-05-2019, 11:52 AM   #4
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
I asked @Moto-P about using different AT fluid vs OEM and he kindly pointed at that our ATs are very finicky and that they were finely tuned to run off of the OEM AT fluids only.
Perhaps he can chime in.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 02-05-2019, 12:14 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Redline D6 seems to hold up to abuse better. I have ran it for over 100k miles and it tends to last about 50% longer then OEM before shifting gets a bit finicky (rough shifts at times usually). This is track time and long canyon drives that put a lot of heat into the transmission. I do a change somewhere between 30k-45k miles. A few other users have noted similar.
If you just DD or abuse it only occasionally OEM is fine. And the dealer can do that no problem.
Old 02-07-2019, 12:45 PM   #6
1quickchic
Drives: 2013 Panda ft86/FRS
I am using Motul Muti ATF https://www.amazon.com/Motul-MTL1057...ords=motul+atf
like others said however, DO NOT HAVE ANYONE FLUSH IT, it will cause damage if they use a machine on it, what I did was drain and fill till it became red again., mine was black..... then one last drain and fill and some lubesgard o it. I also put a huge trans cooler on it as well and well, it drives fantastic, and hold up to my abuse. tbh I would recommend draining the pan and refilling every 20k as these cars do have much in a way of a filter :/
1quickchic is offline   Reply With Quote
Old 02-07-2019, 07:33 PM   #7
new2subaru
Weight Weenie
Drives: 15 FR-S
What trans cooler did you put on?
Old 02-07-2019, 10:41 PM   #8
tyler_win_photo
tyler_win_photo's Avatar
I too run Redline ATF fluid. It's been holding up well to the abuse of FI.
When you take it to the dealer, they may just do a single drain which gets about 1/3 of the fluid actually changed. I'm not sure if that's how they do it all dealerships, but that's how they did it at mine. Preferably they would drain and fill until the fluid is completely pink/red.. which is about 3 times or so.
tyler_win_photo is offline   Reply With Quote
Old 02-07-2019, 11:15 PM   #9
1quickchic
Id have to go look it up, but its a hayden cooler with 6an fittings, its like 12x12"
Old 02-07-2019, 11:18 PM   #10
new2subaru
Weight Weenie
Drives: 15 FR-S
No worries, thanks.
DIY: Automatic Transmission Fluid Change Tristor DIY (Do-It-Yourself) Guides 33 05-24-2024 10:13 PM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
Automatic Transmission Fluid, is this what you use? qijian Engine, Exhaust, Transmission 2 11-30-2017 01:41 AM
AUTOMATIC transmission fluid change DIY?? qijian DIY (Do-It-Yourself) Guides 3 08-31-2017 08:34 AM
AUTOMATIC TRANSMISSION FLUID? How many L ScionFR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-21-2015 12:43 AM
