Old 08-05-2017, 04:42 AM   #1
qijian
Drives: FRS
AUTOMATIC transmission fluid change DIY??
Anyone got a guide w/ pictures or video?
qijian is offline   Reply With Quote
Old 08-06-2017, 01:36 PM   #2
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
It's a total pain in the A**. i can give you just a quick summary. you need to get it to optimal temp. drain it and fill it up again. change gears 20 times going from park to D and back to park. drain it and fill it up etc.. repeat this a few times. then on the last fill up you have to short two of the obd2 pins for the car to display if the temp is correct for the fill up. once the temp is just right you can fill up the trans. you then open up the drain bolt. you'll see fluid coming out. once you have a small steady stream you can close the bolt back up. honestly I Would take it to someone who has done it before or to the dealership. I didn't do it my self but i watched the shop do it.
shaynek is offline   Reply With Quote
Old 08-29-2017, 11:39 AM   #3
EddieZ2
Drives: 2013 FRS
Can confirm....major pain, time consuming.....worth it to pay someone.
EddieZ2 is offline   Reply With Quote
Old 08-31-2017, 08:34 AM   #4
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Can a couple people give some cost figures on about how much it ran them to get the service done? I've heard a lot of different costs that are way different from each other.
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Automatic Transmission Fluid Cooler. ?? connor_lol Engine, Exhaust, Transmission 177 01-02-2023 09:02 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
Changing Automatic Transmission Fluid euthqt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 06-01-2016 03:16 AM
Is it necessary to completely flush automatic transmission fluid? lupindub Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 05-30-2016 02:47 PM
AUTOMATIC TRANSMISSION FLUID? How many L ScionFR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-21-2015 12:43 AM
