Reckless5.86
Drives: 2013 Scion FRS
Recall service at 65k miles
Hey everyone, i'll be taking my car in for the recall with about 65k miles on it. I'm going to have my spark plugs and TOB changed at that time as well. Would it be worth it to have any other things replaced at that time?
The Gunshine State
Drives: '14 BRZ Limited
Check your manual and see what else is recommended at that interval.
![]() Current DD: M235i |
Drives: frs whiteout
I did serpentine belt also,
#4 | |
Sent from my Pixel 2 using Tapatalk |
#5 | |
Country Boy 4 Life
Out Bearing
I LIKE TIRES! |
#6 | |
(it's a part of the clutch system) If your car has an automatic transmission, it doesn't have one. If your car has a manual transmission, I suggest you ask them to replace it with the NEW improved version. humfrz |
#7 | |
I dropped my car off at the dealership this a.m.; got a Camry for the next 10 days. |
#8 | |
![]() humfrz |
JDM Vaping Stance Nation
Drives: 2013 White
While it was quiet and I didn't feel every bump in the road, that ECO Mode is nuts. You can't turn it off and there is a 1-2 second delay when you press the throttle trying to merge before you get out of the ECO mode to get going.
Clueless
#10 | |
See, our cars have an "ECO mode" also - ![]() humfrz |
#11 | |
Drives: 2013 White
My friend who has an earlier Camry even hates it. I did like how roomy it was too.
Clueless
#12 |
Check out the thread in the "recall/issues" section above this one.
| 67k miles, will bring car in for valve spring recall, what else to fix down there? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 12-19-2018 12:59 PM |
| 7,500 miles service ? | juanam0909 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 07-30-2013 05:37 PM |
| Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) | R2RO | Issues | Warranty | Recalls / TSB | 3 | 02-04-2013 10:06 PM |
| Recall I think so!!!! | RWD-boxer | Issues | Warranty | Recalls / TSB | 16 | 10-07-2012 10:39 AM |
| Recall! already | earthsscum | BRZ First-Gen (2012+) — General Topics | 1 | 06-07-2012 07:00 PM |
