Old 01-28-2019, 01:24 PM   #1
CSkap21
Reckless5.86
CSkap21's Avatar
Drives: 2013 Scion FRS
Recall service at 65k miles
Hey everyone, i'll be taking my car in for the recall with about 65k miles on it. I'm going to have my spark plugs and TOB changed at that time as well. Would it be worth it to have any other things replaced at that time?
CSkap21 is offline   Reply With Quote
Old 01-28-2019, 01:44 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Check your manual and see what else is recommended at that interval.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-28-2019, 10:12 PM   #3
swfrs
Drives: frs whiteout
I did serpentine belt also,
swfrs is offline   Reply With Quote
Old 01-30-2019, 10:24 PM   #4
Magoo
Magoo's Avatar
Forgive my ignorance, but what is a TOB? My appointment is this weekend and the car has 130k miles. I changed the spark plugs and serpentine belt at 120k, anything else I should have them replace?
Sent from my Pixel 2 using Tapatalk
Magoo is offline   Reply With Quote
Old 01-30-2019, 10:26 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Throw
Out
Bearing
I LIKE TIRES!
Old 01-31-2019, 01:17 AM   #6
Like ol @Leonardo spelled out TOB = Throw Out Bearing = release bearing.
(it's a part of the clutch system)
If your car has an automatic transmission, it doesn't have one.
If your car has a manual transmission, I suggest you ask them to replace it with the NEW improved version.
Old 02-03-2019, 02:14 AM   #7
Magoo
Magoo's Avatar
Ah, thanks guys. I didn't think about the crappy throw out bearing; that damn thing crapped-out about 10k back so I had the clutch done.
I dropped my car off at the dealership this a.m.; got a Camry for the next 10 days.
Old 02-03-2019, 03:30 AM   #8
Ahhhh - but you just get used to that nice, quiet, soft riding machine -
Old 02-04-2019, 01:44 AM   #9
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
While it was quiet and I didn't feel every bump in the road, that ECO Mode is nuts. You can't turn it off and there is a 1-2 second delay when you press the throttle trying to merge before you get out of the ECO mode to get going.
Clueless
YamahaR86 is offline   Reply With Quote
Old 02-04-2019, 01:52 AM   #10
Kind of like being in the torque dip with the twin when you push on the gas ??
See, our cars have an "ECO mode" also -
Old 02-04-2019, 01:56 AM   #11
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
It's worse in the Camry. I looked it up and it was only in the 2018 MY so far and there have been numerous complaints on their forums and other people are considering a lawsuit.
My friend who has an earlier Camry even hates it.
I did like how roomy it was too.
Clueless
Old 02-04-2019, 04:27 PM   #12
ka-t_240
Check out the thread in the "recall/issues" section above this one.
ka-t_240 is offline   Reply With Quote
67k miles, will bring car in for valve spring recall, what else to fix down there? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 12-19-2018 12:59 PM
7,500 miles service ? juanam0909 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 07-30-2013 05:37 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 10:39 AM
Recall! already earthsscum BRZ First-Gen (2012+) — General Topics 1 06-07-2012 07:00 PM
