Old 01-26-2019, 08:01 PM   #1
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Headlights don't work after Interior Removal
After removing all the interior for the rollcage I found that my headlights don't work anymore, with the exception of flashing the high beams.
Here's what's not working
  • DRLs won't come on
  • Low Beams won't work
  • High beam set on (stick forward) won't work
If I pull the high beam stick back (momentary flash) they will illuminate. Side markers, turn signals, tail lights and brake lights all function normally.
  • I checked the fuses under the hood - all good
  • I checked fuses under the dashboard - all good.
Any thoughts on the subject would be greatly helpful. Thank you.
PRO86 | WTCC | STL
Old 01-26-2019, 08:39 PM   #2
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Check all fuses both inside and in engine bay. May need to trace wiring and connectors.
el-guapin is offline   Reply With Quote
Old 01-26-2019, 09:34 PM   #3
rice_classic
All fuses double checked and good. I haven’t touched anything in the engine bay as the car is unmodified.
This is puzzling.
PRO86 | WTCC | STL
Old 01-26-2019, 09:47 PM   #4
rice_classic
Found it! A black plug behind the radio area was disconnected separating the two harnesses. “Trace connectors” was spot on.
PRO86 | WTCC | STL
Old 01-27-2019, 02:26 AM   #5
humfrz
now, that's ONE cry wolf, you only get two more -
humfrz
Old 01-27-2019, 11:34 PM   #6
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Kudos to You!
Interior door handle removal? hypebrz Cosmetic Modification (Interior/Exterior/Lighting) 3 05-24-2016 12:03 PM
Wiring interior L.E.Ds to come on with the interior lights/headlights TEXAS_LE Electronics | Audio | NAV | Infotainment 2 12-13-2014 09:18 AM
scratch removal products (which ones work?) DarkestBuddha Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 09-06-2013 06:48 PM
Interior panel removal question ft86me Cosmetic Modification (Interior/Exterior/Lighting) 3 07-15-2013 01:36 PM
Silver interior trim removal for plasti-dipping ph0en1xtk Cosmetic Modification (Interior/Exterior/Lighting) 1 10-06-2012 09:54 AM
