Old 01-19-2019, 01:58 AM   #1
Boris_Petrov
Drives: 2013 GT 86
Lowering compression
So I'm gonna start this off by saying that I live in Bulgaria and I have no access to ethanol. I am planning to turbocharge my 86 with the FBM stage 1 turbo kit with a gtx2867 or a gtx3076R and that's what this post is about. I'm looking to make around 380 - 400 hp and with no access to ethanol I might have to lower the comp to 10 or 10.5 to allow more boost on 100 RON. Do you think I should lower the comp, because LJ did a test on the stock motor with a gtx35 and got to around 500 hp? And if I do, should I go for the GTX3076R?
Sent from my SM-A520F using Tapatalk
Boris_Petrov is offline   Reply With Quote
Old 01-19-2019, 03:58 AM   #2
JIM THEO
Drives: BRZ 2018
Boris imho you ask for too much power from a non turbo engine (and RWD light car).
Even ΟΕΜ turbo 2.0L cars have much lower power output although the extensive R&D and strengthened internals!
From personal experience you have some gas stations w/ very good quality gas (some Gazprom I tried were much better than our poor quality 100RON) so may be you should set lower boost and work with 11+:1 or the OEM compression ratio?
PS: By the way where exactly are you from, I have a company established in Blagoevgrad?
JIM THEO is offline   Reply With Quote
The Following User Says Thank You to JIM THEO For This Useful Post:
Boris_Petrov (01-19-2019)
Old 01-19-2019, 04:19 AM   #3
Boris_Petrov
Drives: 2013 GT 86
I'm from the capital Sofia, but from what I know gas here is much shittier in comparison to Germany or even Russia. And why do you think this is too much power? I mean, I've seen many people on the internet with reliable 450 TC builds. And I haven't seen 11 or 12 pistons. There are 10.5 and 12.5 as far as I know.
Old 01-19-2019, 05:19 AM   #4
JIM THEO
Drives: BRZ 2018
If you refer to gas stations say around Nurbgurging yes it's much better than yours but generally speaking and logging my knock correction here and in Bulgaria I can say for sure you have good quality 100RON gas.
I didn't search what pistons are available for your application just saying an opinion as you want to double the factory power with whatever this means!
Dropping the compression? wunslowbrz Engine, Exhaust, Transmission 4 07-12-2016 06:02 PM
compression ratio nexusatm Forced Induction 38 05-13-2016 07:59 AM
Compression/cylinder? Amir Ghadiri Engine, Exhaust, Transmission 4 02-21-2015 02:23 AM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
