Old 02-20-2015, 12:25 PM   #1
Amir Ghadiri
Amir Ghadiri's Avatar
Compression/cylinder?
Anybody know how much compression our motors should be showing per cylinder? I checked on ProDemand and it's showing 167 PSI min, 254 PSI max, 29 PSI max variance. Can anybody confirm this?
Thanks
Amir Ghadiri is offline   Reply With Quote
Old 02-20-2015, 12:30 PM   #2
350matt
Drives: toyota mr2/ Toyota GT86
when I checked mine it was about 180psi on all cylinders
350matt is offline   Reply With Quote
The Following User Says Thank You to 350matt For This Useful Post:
Amir Ghadiri (02-21-2015)
Old 02-20-2015, 12:34 PM   #3
Amir Ghadiri
That's what I thought it should be at, thank you!
Old 02-20-2015, 01:17 PM   #4
stugray
Drives: 2013 GBS BRZ Limited
14.7 PSI (atmospheric pressure at your altitude) * 12.5 (86 compression ratio ) = 183.75 PSI.
So that is the number that you should never be able to exceed with "static" CR (cranking it).
At full speed, the "dynamic CR" is different.
The Following 3 Users Say Thank You to stugray For This Useful Post:
Amir Ghadiri (02-21-2015), cdrazic93 (02-21-2015), joe strummer (02-20-2015)
Old 02-21-2015, 02:23 AM   #5
Amir Ghadiri
Thank you very much, I appreciate it!!
compression+boost? subatoy Forced Induction 74 01-30-2015 04:32 PM
Compression/Rebound Adjustments amaciose Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 12-10-2014 04:51 AM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Low Compression Pistons vs New Shortblock SilverTipp Forced Induction 11 04-11-2014 05:45 PM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
