Old 06-16-2014, 10:21 PM   #1
Venator
Venator's Avatar
Drives: Asphalt FR-S
Low compression?
Sorry for the possibly noob question but what's the point of a low compression built motor? Are they any good NA or only FI?
Thanks!!!
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 06-16-2014, 10:38 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The higher the compression the more HP you'll get out of it NA (in theory, there are limits). In NA builds sometimes youll see custom pistons increasing the CR along with other things like cams, headwork, sleeves, blah blah blah.
Lower compression for FI means you can push more boost safely. Lower compression from stock will result in a smaller gain in HP per PSI of boost as compared to stock 12.5:1 CR. On the flip side youll be able to run more PSI.
My $.02 is that if you want to run more than 12ish PSI then you can lower the compression to ~ 10.5:1. If you plan on pushing more than 20 PSI then >10:1
This is on pump gas ofcourse. E85 is a different story.
Old 06-16-2014, 10:54 PM   #3
Venator
Venator's Avatar
So lower compression means more safe boost but less hp per psi. So the only reason to lower CR is push lots more boost?
Old 06-17-2014, 10:31 AM   #4
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
In a nutshell, yes.
Smudgeous is offline   Reply With Quote
Old 06-17-2014, 10:37 AM   #5
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Essentially what your dealing with is octane limitations when your talking about amount of boost vs. static compression.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
compression+boost? subatoy Forced Induction 74 01-30-2015 04:32 PM
High Compression pistons EN2_Squirrel Engine, Exhaust, Transmission 23 05-01-2014 02:29 PM
Low Compression Pistons vs New Shortblock SilverTipp Forced Induction 11 04-11-2014 05:45 PM
Lower Compression with Headgasket Team STILLEN Engine, Exhaust, Transmission 28 12-15-2013 05:26 PM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
